Question for O2 sim users...
Old Aug 8, 2007 | 07:04 AM
rmh3093's Avatar
Only gentoo powered Maxima!
For those using O2 sims, does your service engine light actually stay off forever. I have been using an O2 sim to shut up my service engine light since last summer when I got my y-pipe. Since then I have passed two NYS inspections with it. However, the service engine light still pops back up time to time. Usually after its rains when its all foggy out (either late at night or early in the morning) is when it usually turns on for me. I guess this isnt a big deal but I was just curious what other people experienced.
Old Aug 8, 2007 | 07:11 AM
upstatemax's Avatar
Mine will pop up everyonce in a while, usually on long road trips.
Old Aug 8, 2007 | 08:17 AM
knight_yyz's Avatar
Toolie
mine comes and goes too. Stays off for a month, pops on for a few days, goes away again. Mine always pops on when I start the car though. It's never come on while driving.
Old Aug 8, 2007 | 08:48 AM
klee215's Avatar
i just installed mine about a month ago .. and no problems yet *knock on wood*...
Old Aug 8, 2007 | 12:17 PM
huffdaddy2008's Avatar
Mine throws codes every once in a while. Its always been heater circuit codes though. I can always just clear it and it goes away.
Old Aug 8, 2007 | 12:28 PM
rmh3093's Avatar
Thats weird, you shouldnt get the heater code if you are faking an O2 sensor... since the sim needs an intact heater. I always get the catalyst deficiency code.
Old Aug 8, 2007 | 12:45 PM
13sFTMFW's Avatar
im gunna thread jack a little bit!!!
my engine light has been on since i put the headers on. its the O2 codes comin back, where can i find the sim, or would just a spacer work???
Old Aug 8, 2007 | 02:12 PM
Its more common than u think. Heres some interesting reading. http://forums.maxima.org/showthread.php?t=435399
www.02simulator.com also the first page of the header sticky
Old Aug 8, 2007 | 03:30 PM
rmh3093's Avatar
if you can solder i posted a schematic with a part list from radio shack... it cost ~$10 to make your self... mine has been working great.... if you dont want to build it then order it from o2sim.com
Old Aug 8, 2007 | 06:24 PM
Puppetmaster's Avatar
I have a dual output sim and no precats, and the MIL has been off since April 2006. I've passed two VA state OBD-II based inspections since as well.
Old Aug 9, 2007 | 07:33 AM
pimpin02max's Avatar
Everything form what I have seen says that you should get the dual output sim and then get 2 bungs welded after the the main cat so you won't get the heater code...
Old Aug 9, 2007 | 07:44 AM
You don't need to bung the O2s if you leave them plugged in, along with the sim. Heck, if you successfully extend the O2 wires to reach the bungs, you won't even need a sim.
Many of you have already seen this, but I'll post it again:
This is where my rear O2s are and I have no heater codes.
Old Aug 13, 2007 | 05:27 AM
rmh3093's Avatar
of the people who still throw random codes, has anyone else noticed if their CEL comes on when its foggy out. I am beginning to think that its poor connections on the signal wire... im going to un tape things and solder the wires, then seal up the wire with liquid tape, I hope that works
Old Aug 13, 2007 | 05:57 AM
Trurida18's Avatar
well cant you use regular O2 sensors instead of the simulators? Or will the aftermarket Y-Pipe kill them or something
Old Aug 13, 2007 | 06:15 AM
rmh3093's Avatar
with an aftermarket y-pipe you dont have any pre-cats so even if the o2 sensors are in working condition they will report that the pre-cats are working like they should and you will get a CEL... hence the need for the simulator
Old Aug 13, 2007 | 06:44 AM
Trurida18's Avatar
^^ ok thanks.....So basically ill still be forced to use a universal O2 simulator and splice the connectors if i upgrade Y-Pipes
Old Aug 25, 2007 | 03:00 PM
maximadotorg
so what do you have plugged into the holes on the ypipe?
Old Aug 25, 2007 | 03:03 PM
NmexMAX's Avatar
dot dot dot ...
He has headers, so aside from the primary o2 ports, there are no other holes.
Old Aug 25, 2007 | 03:20 PM
maximadotorg
i have a 4th gen with warpspeed ypipe
as you know there are two o2 sensor holes..
can i do the same thing as that guy and leave the sensors out and weld the holes
Old Aug 25, 2007 | 03:39 PM
NmexMAX's Avatar
dot dot dot ...
Why would you do that?
Old Aug 25, 2007 | 03:44 PM
maximadotorg
to get rid of the o2 CEL for ever and ever..
hey maybe i'm missing something here... what do i do with the o2 sim ?
Old Aug 25, 2007 | 03:46 PM
NmexMAX's Avatar
dot dot dot ...
You still need your primary O2 sensors functional. Is your car cali spec? How man o2 sensors do you have total?
Old Aug 25, 2007 | 03:55 PM
maximadotorg
fed spec 1995 maxima
2 front
and
1 on cat
Old Aug 25, 2007 | 03:57 PM
NmexMAX's Avatar
dot dot dot ...
Ok, if you have a rear o2 code then do it, if not
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
