Question on Front Struts
Old Aug 10, 2007 | 08:50 AM
Old Blue 66's Avatar
Ive got 145,000 on my 2000 SE and never replaced the struts. I now realize they are worn out. What do I need to replace them with?? The key word here is NEED because Im not sure how long Ill have the car and dont want to spend a fortune on expensive factory units (dealer quoted me $225.00 each w/o uinstallation).
Will a pair of Monroe Sense-O-Matic units work?? They cost about $100.00 a piece.
Old Aug 10, 2007 | 10:42 AM
Professor's Avatar
Go to a parts store, aka auto zone or advance auto parts, I got my struts there for $201 for the pair. I installed them in the parking lot in like 2 hours, all you need is a spring compressor, a electric impact drill for the top nut or air gun, a breaker bar for the 2 bolts on the lower strut and like a 10 or 12 mm socket for the top 3 that hold the strut mount it, just take out the 2 bottom ones, take off the brake line connected to the strut and abs wire, remove the 3 top bolts and the whole assembly will come out, compress the spring with a GOOD spring compressor , remove the center nut on top, remove the spring from the strut, slap in the new one, line up the spring seats, tighten top nut, reinstall, there is no camber adjustment so you shouldent have to get a alignment. Unless you have lowering springs etc.
Old Aug 10, 2007 | 12:35 PM
stocked out max's Avatar
i just put a pair of monroe sensa-trac on the front end, and it feels good. you will def notice breaking and cornering to be greatly improved(was also on my orig equipment)
Old Aug 10, 2007 | 02:58 PM
Trurida18's Avatar
so i guess the sensatrac's are pretty good...for the buck
Old Aug 10, 2007 | 03:49 PM
id rather save money for a place of my own and a new car then go all out on a car thats seven years old with 124k worth of miles...so yah good for the buck
Old Aug 10, 2007 | 06:24 PM
Trurida18's Avatar
respectively........can't blame u for that at all
Old Aug 11, 2007 | 05:22 AM
Ok, then the Monroe's it is. They're so bad, they're rattling around. Im putting on new tires at the same time, so i cant wait to drive it after its all done. Should feel like a different car.
Im not investing too much money in this car because I may get rid of it in a few months or I may keep it for anothe couple of years. The guy in the parts departrment at the Nissan dealer said I should get another 145k ouot of this thing. Which Ive heard several times before.
Old Aug 11, 2007 | 05:26 AM
AceofSpds's Avatar
wat
Probably need new strut mounts also
Old Aug 11, 2007 | 06:12 AM
nlmaxima's Avatar
You still need an alignment when replacing struts.
kingw323
20
Oct 21, 2015 08:36 AM
95Maxi
35
Sep 2, 2015 10:37 AM
MaxStock
Aug 14, 2015 10:01 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
