Moog Sway Bar Link
Moog Sway Bar Link
I purchased the Moog sway bar link and quite stumped with the lack of documentation provided by the supplier.
It come with a 2 nuts a 2 grease nipples (since I don't know how to upload the photo, will make the best by writing). Anyway, the links itself have a hole to stick in the nipples but I want to understand do I have to grease it with a grease gun after put the nipple and tightening it.
I would have thought the manufacturer should have all installed with the grease in it.
Any suggestions will help.
I bought is almost a yr ago and kept it in the garage. Either I use it or discard it, but then since the nipples are off from the supplier, I can apply grease (Mobil1 synthetic grease) using my fingers and then thread in the nipples for good.
What surprises me I got the stuff from
http://www.autopartswarehouse.com/
and it is off the list of replacement items. I actually went for Moog since they are highly recommended replacement suspension manufacturer (paying a premium). Anyway, I will just apply grease into it and thread in the nipple for good and call it a day!!!
OEM links lasted 130K, if this lasts another 70K, I will be happy..
Installed it, pretty simple except for the nuts, with all the must and brake dust it was stuck pretty well. Penentrating fluid made it break loose.
What a difference in ride, thorougly impressed. No longer notice those little bumps, pleasant ride. Strongly recommend replacing it first if you have many miles.
In the process broke a lug nut. Idiots at Costco had over torqued it. Need to get that fixed sooner or later.
Do not use a washer. The nuts has a rough surface to grip properly on the sway bar and the control arm. If you use a washer you'll lose part of this grip.
wow thanks for that i'm about to buy some washers... i keep hearing people say this moog part unscrews over a few months. any idea if i should use the moog or take it back for a "master pro" O'Reilly brand part?
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
rbaker100
Sep 25, 2015 07:52 PM
