Need Help with Wiring, Please
Old Jul 20, 2001 | 12:13 PM
Empz's Avatar
Hey Guys,
I'm gonna be wiring up some LED's to my car ... more specifically I'm going to be Tapping into the PARKING/CORNER/BLINKERS (or whatever U want to call it)
** I want the LED's to go on When the Parking lights are on, and Flash when I Signal **
Here's the Problem ...
There are 3 Lines attatched to them:
1) RED (Power ?)
2) BLACK (Ground ?)
3) GREEN (NO CLUE ???)
I'm going to be Hooking up the RED Wire(from LED) to the RED Wire(attached to Parking Light)
Now where do I hook up the BLACK Wire(from LED) ????
** Don't forget I want it to BLINK when I signal **
Thanx,
Eric
Old Jul 20, 2001 | 12:23 PM
UMD_MaxSE's Avatar
Got Bent?
Green is usually also ground as far as I know....
Old Jul 20, 2001 | 05:47 PM
ToYLeT902's Avatar
JET Speed Lab
im getting mine professionally done, i dont want to bother with the wires. going to hook them up to my fog light switch
Old Jul 20, 2001 | 06:27 PM
BigDogJonx's Avatar
Originally posted by Empz
Hey Guys,
1) RED (Power ?)
2) BLACK (Ground ?)
Thanx,
Eric
First of all, The black is Ground, The red wire is for the parking lights, not the blinkers. Just parking lights. The GREEN wire is for the turn signal blinkers. That means if you want to make the LEDs blink with the turn signals, you want to hook up the black wire from the led to the black or just ground it if that is easier. And then hook up the RED wire from the LEDs to the GREEN wire coming out of your orange corner light.
GOT IT? Dont worry about putting any load on that light, since you got LEDs, the load is barely measurable on a tester.
Dixit
Old Jul 20, 2001 | 07:31 PM
jsmith24's Avatar
Dixit
Yeah, but depending on where he got the LEDs, he may need to consider the putting on a voltage drop/current limiting resistor. Aren't those blinkers 12 volts? Most LEDs will pop over 3v.
Jack
Old Jul 20, 2001 | 07:37 PM
BigDogJonx's Avatar
Originally posted by jsmith24
I've just gotta ask - why do you sign with "dixit"? Now, I know what it means...just curious why you use it.
Jack
Just so used to doing it at work with all the email I write. So I do it all the time. It is my First name. Just been doing it all the time.
Dixit
Old Jul 20, 2001 | 07:40 PM
jsmith24's Avatar
You are correct, I was only assuming that either the LEDs were 12v or that he had the whole circuitry built in.
Dixit
Jack
Old Jul 20, 2001 | 10:46 PM
Empz's Avatar
Hey THANX BIG Time man!
I got a little Confused and I did RED on RED and BLACK on GREEN Today ... and that got F*cked up!!!
I was NOT able to Signal ... When I signaled, BOTH lights went on (as if I turned on my Hazards)
BUT If I do BLACK On BLACK and RED on GREEN ... will the Lights Turn ON When I have my Parking Lights are on????????
Thanx,
Eric
Dixit
Old Jul 20, 2001 | 10:55 PM
BigDogJonx's Avatar
They will only signal.
No they will only signal if you connect to the green. If you do red on red, then they will not signal, they will only act as parking lights.
Dixit
Old Jul 20, 2001 | 10:58 PM
Empz's Avatar
Re: They will only signal.
<sigh>
I guess I can't have Best of Both Worlds .... Sucky!!!
THANX again!
Dixit
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
