View Poll Results: Do you think the SSIM is good or bad
I think it makes good power for what it's worth
64.71%
I think it is bad and all it does it make you lose power.
35.29%
Voters: 17. You may not vote on this poll
Removed my IM butterfly valve
Old Aug 17, 2007 | 01:45 PM
  #81
SR20DEN's Avatar
VQ Wizard
I voted in this thread
Old Aug 17, 2007 | 01:48 PM
  #82
DasYears
people that already have this mod have voted no...interesting
Old Aug 17, 2007 | 02:03 PM
  #83
pimpin02max's Avatar
Are you joking me...you honestly voted no??? is up with that SR20??? Oh well either way I am doing this mod.
Old Aug 17, 2007 | 02:45 PM
  #84
MacGarnicle's Avatar
Originally Posted by soonerfan
it depends on what you are doing
drag racing...might help
i auto-x and spend all my time at low end...im not giving that up
exactly.. unless your car spends most of its time at high revs, doesnt seem worthwhile.
Old Aug 17, 2007 | 02:49 PM
  #85
upstatemax's Avatar
What if I live my life a 1/4mile at a time?
Old Aug 17, 2007 | 02:56 PM
  #86
What exactly are you calling gay about my post...oh and I don't know about you but ugh yeah whenever I race doing anything my car seems to get in the upper rpm's...I guess some of you guys shift at 3000rpm's..
If you don't think the mod is worthwhile then STFU and don't do it...
Old Aug 17, 2007 | 03:11 PM
  #87
DasYears
you cant say that in a thread where you asked for opinions
Old Aug 17, 2007 | 03:30 PM
  #88
No...you don't understand that guy has been on here ever since I started the 1st thread saying what I did...I think he has said about 20 times..."I just don't know about this mod, I don't know if it's worthwhile..." jeez buddy if you don't think it's worthwhile then don't do it...don't just keep saying "I don't think it's worthwhile" and then it certainly doesn't help that he says one of my posts are
Old Aug 17, 2007 | 03:42 PM
  #89
nismopc's Avatar
In nobody's defense, I drive my Max daily. I spend 2 hours round trip commuting to and from work. When I am not on the hwy, I am almost always running my rpm's well over 3000k.
I'll take a stab in the dark that the VIAS control was set-up for people who don't "mod" their cars much and basically drive within the mfg. recommended shift points, etc.
I have no hard facts that this mod does or does not work, but hopefully will soon enough. I dynoed my car early summer with just a modified intake. My block-off plate will be here early next week and I will be dynoing again on Sept 29th on the same exact dyno as the first (if all goes well with an upcoming meet here in ohio). Hopefully, the surrounding factors will be very similiar to last time and I will be able to see a before and after comparison.
As a side note: Reason I decided on the block-off plate was it was either that for $25 or to buy a new VIAS solenoid for close to $200. My VIAS solenoid crapped out on me w/o any warning about 2 months ago. So, I chose the cheaper alternative.
Old Aug 17, 2007 | 03:56 PM
  #90
DasYears
are you doing the full mod or only block-off plate?
Old Aug 17, 2007 | 04:15 PM
  #91
NmexMAX's Avatar
dot dot dot ...
Who said I have an L-spec? Must not know me nor my mods very well.
Old Aug 17, 2007 | 05:02 PM
  #92
I didn't know...I was just assuming...
Old Aug 17, 2007 | 06:57 PM
  #93
nismopc's Avatar
I will be doing only the block-off plate. This should put into perspective the gains/losses once I get the dyno results.
Honestly, I'll state right now because my VIAS is shot, I am bypassing the VIAS by nippling off the vacuum line from the solenod which allows the butterfly to sit in open position al the time. The car screams. If I force the pedal at wot on take off, the tires spin in first without me dropping the clutch and if I shift to second swfitly, the tires just spin like mad. I never recall having this amount of force ever since I've owned the car. I bought the car with 59k and it now has 103k.
But as we all know, butt dyno's are bogus crap. So I hope to see positive info when I get dyno'd.
Old Aug 17, 2007 | 07:57 PM
  #94
NmexMAX's Avatar
dot dot dot ...
Interesting. The 2 on the far right look like, well, they might be good. grade JW are they?
I'm guessing you haven't looked @ my ignition timing curve or CVTC curves? Well, in any case, this statement proves a few things.
I felt the same way when I dc'd my VIAS. I was just like you and everyone else who swore there were gains. juice told me what I'm telling you fellas. I didn't believe him, went to dyno, and proved myself wrong.
x3
http://forums.maxima.org/showpost.ph...8&postcount=33
Old Aug 17, 2007 | 08:07 PM
  #95
SR20DEN's Avatar
VQ Wizard
You already said I didn't know what I was talking about. so...
Old Aug 17, 2007 | 09:27 PM
  #96
No no no no no...I was being sarcastic toward NmexMax b/c he was saying that the SSIM doesn't make power so I said "well then I guess SR20DEN doesn't know what he's doing" b/c I know that you would not have pushed the SSIM if it did not show gains....trust me I know that you know what you are talking about....
Old Aug 17, 2007 | 09:30 PM
  #97
See that's the exact same I was whenever I first put it on there...my car broke loose in 1st completely (never done that before) still don't know why it did either...but then after I found out more about the VIAS then it hit me that it actually wasn't doing much if anything...however I still do think that the SSIM will help me out.
Old Aug 17, 2007 | 11:13 PM
  #98
NmexMAX's Avatar
dot dot dot ...
Ok, so who's side are you taking?
Old Aug 17, 2007 | 11:24 PM
  #99
NmexMAX's Avatar
dot dot dot ...
I took all my advice from this man, so then....that would mean, I don't know I'm talking about.
Wow, I must suck But at the same time
Old Aug 18, 2007 | 06:48 AM
  #100
Whoa...I'm getting all confused, yeah I guess SR20 took my sarcasm against him the wrong way...
But NmexMax I am on nobody's side...I understand your points and I know that you know your stuff...it's just that both some of the stuff that we have said is true...I know though that just the VIAS removed isn't doing much at all but...I am talking about the full SSIM.
Old Aug 18, 2007 | 05:10 PM
  #101
Puppetmaster's Avatar
Old Aug 18, 2007 | 06:58 PM
  #102
NmexMAX's Avatar
dot dot dot ...
The last sentence from post #48 comes to mind.
Old Aug 18, 2007 | 09:20 PM
  #103
Stardust's Avatar
F---ing Kangaroos
Originally Posted by Puppetmaster
Whos the best 5th gen moderator?... Joel is
Old Aug 18, 2007 | 09:22 PM
  #104
Stardust's Avatar
F---ing Kangaroos
Thats just plain dumb, you should NEVER assume anything here.
Old Aug 18, 2007 | 09:24 PM
  #105
Stardust's Avatar
F---ing Kangaroos
Can you quote it for me? I can't seem to find it, I searched and everything
Old Aug 18, 2007 | 09:27 PM
  #106
Stardust's Avatar
F---ing Kangaroos
Old Aug 18, 2007 | 09:32 PM
  #107
Stardust's Avatar
F---ing Kangaroos
it makes your car faster...
Lies, all lies. Torque wins races
If I wanted a topend monster I would buy a Honduh
Old Aug 18, 2007 | 10:14 PM
  #108
SoonerFan's Avatar
Cletus
Torque is more important than horsepower
Old Aug 19, 2007 | 05:47 AM
  #109
sciff5's Avatar
Actually hot rod magazine did an article about this it was called Bore vs stroke. They took 2 engines of the same displacement one with a long stroke (more torque) and one with a larger bore (more hp) and they found that in terms of the quarter mile both cars came out about even.. of course I thought the whole test was stupid as hell because its not that simple at all and for you to make a blanket statement such as the one you've made above makes me wonder about your knowledge base.
If you want to open up the subject in another thread.. I will entertain some banter
Old Aug 19, 2007 | 07:15 AM
  #110
rmh3093's Avatar
Only gentoo powered Maxima!
torque only helps for 1/2 of each gear.... you still need hp to be a contender
Old Aug 19, 2007 | 07:35 AM
  #111
Well for you that may be true...but I mostly run the 1/4 so I am only at a low rpm for a small amount of time in 1st and then the rest is up top where all of my power will be so it is better for me...but if I autocrossed like some of you guys then no I would definitely not do this.
Old Aug 19, 2007 | 07:43 AM
  #112
Actually that is not a lie...sure torque is very important but if you have all that power off of the line and no horsepower to back it up...your screwed, look at like a SN95 Mustang...they have 285 ft/lbs of torque but only 215 horsepower...they run low 15's Also look at a Honda S2000...like you said they have good top end well an S2000 has 237 horsepower and only 162 ft/lbs of torque...they run low 14's. It isn't all about horsepower but it isn't all about torque either It's about a good combination and well with a VQ35 under my hood I will still be torquey with this mod as well as have even better top end.
Old Aug 19, 2007 | 08:32 AM
  #113
Whitebread's Avatar
Torque and horsepower are both very, very important. Torque is the rotational analog of force. It directly determines the amount of force the car exerts on the ground at the wheels. The ground exerts the exact amount of force (assuming the tires do not loose traction) and the car accelerates forward. Horsepower is a measure of an engines ability to do work. AS RPMs increase, torque decreases and hp increases. The engines ability to do work increases and the car will accelerate faster.
At lower engine speed, a greater amount of torque is applied over a short distance (RPM) per unit time (seconds). As engine speed increases, torque decreases, but the engine applies said torque over a much greater distance per unit time. This is why the engine can do more work and the car can accelerate faster.
Both are very very important.
Old Aug 19, 2007 | 02:44 PM
  #114
bwinter7's Avatar
Nice I think I've read that manual of engine physics before, that where you copied/pasted from? j/k
Everyone knows that you need torque just as much as HP, but you can't compare to autocrossing to 1/4 spurts. I have never done either of them and I know you cant compare them. You need more torque in auto x-ing because you slow down for corners, accellerate through them at a generally lower speed/rpm so you're not going 45 in 2nd through a 90 turn @ a very high rpm(right? auto x-ers help me out here, I may be wrong) I'd firgure that you want more midrange torque from about 3-4.5k going through a turn to utilize your torque-curve better.
So, as it has been said before, 1/4 mile people might want to do the full mod (gutted IM and removal of the BF valve) but auto x-ers wont.
Old Aug 19, 2007 | 03:48 PM
  #115
I like just said basically that same thing....read post #111
Old Aug 19, 2007 | 07:17 PM
  #116
Whitebread's Avatar
I'm an engineering student focusing on automotive technologies. Understanding the very basics of engine operation is a necessity.
Also, I wasn't trying to make commentary about autoX and drag racing with my first post in this thread. But I will do so now.
I think the reason people say torque is more important in autoX than draging is because of the region the engine operates in. As you stated, auto crossers don't usually drive at high speeds (60+) and are cornering at very low speeds whereas drag racers are WOT the whole way down the track. They shift high and keep the throttle pegged.
What I think you really want in an autoX car is an engine that can do the most work at low engine speeds. Saying torque is more important than horsepower for an autoX engine isn't technically correct. It just so happens that in order to do more work at low engine speeds, you want a car with "more low end torque". The opposite is true for a drag engine. You should be shifting when the engine makes peak HP and unless you have a tranny with wide *** ratios, the engine will only drop a few thousand RPMs. The engine stays in the upper part of its power band; low end performance isn't as important.
Old Aug 19, 2007 | 07:34 PM
  #117
THANK YOU....that is what I have been trying to tell everybody...that's exactly why I am doing this mod, I only race in straight lines
Old Aug 19, 2007 | 07:40 PM
  #118
Stardust's Avatar
F---ing Kangaroos
Old Aug 19, 2007 | 07:51 PM
  #119
You know what...take a look at your avatar and listen to it...do us all a favor
Old Aug 19, 2007 | 08:28 PM
  #120
Stardust's Avatar
F---ing Kangaroos
Buy a bullet and rent a gun
