Low Timing
Old Aug 27, 2007 | 05:57 PM
Wheelie King's Avatar
Low Timing
The timing on my '03 is down around 9-10 degrees at idle instead of the usual 14 degrees. Its an '03 with 125k miles and no codes showing. I did a timing bump which got it up to 10-11 degrees. I use 93 octane gas.
Does anybody know what could be causing the low timing?
Old Aug 27, 2007 | 06:05 PM
NmexMAX's Avatar
dot dot dot ...
How about @ WOT? Do you have a WOT timing graph? Mine sometimes hangs @ 12*, depending if I'm in P/N.
But my WOT logs are healthy.
Old Aug 27, 2007 | 09:25 PM
SuperStasiu's Avatar
I think thats normal at idle if you have access to the nissan consult tool you can check the main timing which should be at 15
Old Aug 27, 2007 | 09:37 PM
NmexMAX's Avatar
dot dot dot ...
What do you mean by 'main timing'? <--FSM says @ 'idle' in P/N. And that's where data should be taken.
Old Aug 29, 2007 | 12:15 PM
NisTech's Avatar
it should at 15.
You might have a bad knock sensor and your ECM retards timing.
Knock sensor won't give you a light but it will show up if you scan it.
They go bad all the time on those years
Old Aug 29, 2007 | 02:43 PM
NmexMAX's Avatar
dot dot dot ...
On 03's ???
Old Aug 29, 2007 | 07:17 PM
I had a 97 which was known for a sensitive knock sensor. I'll look into it with the 03.
I don't know what WOT is. I'll look into it though.
Thanks.
Old Aug 30, 2007 | 07:44 PM
NisTech's Avatar
NOT THE O3S NEVER SEEN ONE.
95-99 ONES ALL THE TIME. sAME WITH XTERRAS. PATHFINDERS
Finkle
Sep 27, 2015 09:53 PM
Slamrod
Sep 3, 2015 07:38 PM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
