Why are the back of these two headunits different if they are the same year? LOOK!
Old 09-06-2007 | 09:51 AM
scheibler's Avatar
I am looking to buy a stock 2000 or 2001 headunit becasue as I understand, they are essentially the same and will both work in a 2000 Max. I was searching ebay for a non-bose headunit when I noticed something strange The back of one headunit only had one white harness connecter where as the other has two harness spots. What is the difference and can I use either? I have two connectors connected to my current headunit. Here they are:
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=001
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=006
Also, do I have to worry about headunits being theft locked or should any work?
Old 09-06-2007 | 09:55 AM
Professor's Avatar
One for bose equiped systems one without the bose system like mine, no sub just 4 door speakers and 2 a pillar tweets, second one is the one mine has
Old 09-06-2007 | 09:58 AM
scheibler's Avatar
I definately want the cheaper one lol, but thats confusing because neither of them says bose on the front of the headunit in the cassett player and both are listed as non-bose...should I go ahead and buy the cheaper one?
Old 09-06-2007 | 10:01 AM
DasYears
i thought bose at first too, but then neither one says bose...just look at the back of your unit and see how many connectors you need
Old 09-06-2007 | 10:03 AM
scheibler's Avatar
Mine has two connectors, but I dont know what they do? Is it ok to use teh headunit with only 1 connector
Old 09-06-2007 | 01:42 PM
misiek's Avatar
the headunits are always made by the same company (in this case clarion).... the only thing that bose makes are the speakers and amp because thats the only thing that would improve the sound.... i have the rockford fosgate premium sound in my frontier but the headunit is the same as my buddies "stock" headunit in his pathfinder but the rockford speakers sound alot better then stock.... if u have non-bose system in your car go with the one plug the 2 plug radio is for the bose amps and speaker setup
Old 09-06-2007 | 01:49 PM
DasYears
99% certain my HU says bose on it
Old 09-06-2007 | 02:02 PM
DasYears
Old 09-06-2007 | 03:11 PM
TurtleHead
Originally Posted by scheibler
the problem is that I replaced my stock one with a kenwood becasue I had a subwoofer setup and my buddy's mom threw away my stock headunit. I won't be able to tell unless I unhook my headunit. I no longer have the sub and the reception on my kenwood hu is terrible
Did you forget to hook up the amp wire for the antenna? Even though the stock antenna cable was plugged into the back, I forgot to attach the wire to power the antenna amp.
Old 09-06-2007 | 03:49 PM
scheibler's Avatar
no it works, but its just staticky. I decided to take out the headunit all together and solve my own problem. My max does have to the white connecters. I wonder what they do and if I really need them both because some only use one like the one shown in the ebay link
Old 09-06-2007 | 04:05 PM
Professor's Avatar
so theres a amplifier for the antenna on the 5th gens? i did not notice when i installed my new head unit and bought a crappy adapter for the antenna 2 pin connector, My reception suck, i assume thats the reason then, but i dont recall anything like that and i dont have the premium package.
Old 09-06-2007 | 04:38 PM
TurtleHead
Yes, the amp I believe is in the rear passenger side area. I have a 01 without premium sound and I have it.
I couldn't figure out why my new deck reception was crap until someone on here told me about this wire I thought was not used for anything. Hooked that amp wire back up and wala, I got great reception. I cant recall what color it was, I think it was blue like the normal amp signal wire/power antenna.
Old 09-06-2007 | 08:54 PM
kramarz99
I have changed 3 HU and they all work fine...BTW, they all were Bose HU...
JRod28
12-29-2023 09:56 PM
Finkle
09-27-2015 09:53 PM
maxinout93
08-20-2015 02:17 AM
Abdelrhman
08-17-2015 12:16 PM
FanaticMadMax
08-10-2015 08:55 PM
Quick Reply: Why are the back of these two headunits different if they are the same year? LOOK!
