rewired fogs ------glown fuse
Old Jul 26, 2001 | 09:45 AM
rino_2kmax's Avatar
i have my fogs lights rewired
with parking light
i blown 3 fuse so far
15 amp , 15amp and 20 amp
what is causing the fuses to blow???
do i need to move up to 25????
Old Jul 26, 2001 | 12:27 PM
jazzy8's Avatar
If you rewired the fogs using the instructions in the How to's - you shouldn't even need a fuse. What fuse are you blowing, one you added or a stock one?
Old Jul 26, 2001 | 12:36 PM
rino_2kmax's Avatar
im blowing the fuse that is under the stering wheel
i hooked up everthing like in the how tos but i keep blowing that fuse
Old Jul 26, 2001 | 01:07 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Describe what you did. You shouldn't need a fuse, but I added an inline fuse to be safe. So far, I haven't blown any. However, I wired mine to the running lamp bulb that is also the turn signal in the headlamp housing. I deactivated my running lamps(piece of tape over one of the two knubs), so it only flashes. Therefore, there is no load except the fog lamp relay, which is not very much and shouldn't need a higher wattage fuse.
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
leatherneck
Sep 30, 2015 09:16 PM
