New transmission TSB - 039B
Old Jul 31, 2001 | 06:40 AM
nm's Avatar
nm
Has anyone seen this tsb or know what it says?
Heres the direct webpage link to it on the www.nhtsa.dot.gov site:
http://www.nhtsa.dot.gov/cars/proble...0%20&year=2000
I would appreciate any info you have, especially after my transmission made a "trrrrrrt trrrrrrrt wham!!!" sound when I was pulling out of a parking lot this weekend.
Old Jul 31, 2001 | 06:54 AM
UMD_MaxSE's Avatar
Got Bent?
sounds like the symptoms described in the previous one in the sticky thread above. Is it newer than that one?
Old Jul 31, 2001 | 07:02 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
The shift solenoid might be the one I have... but until we see the part number.
Old Jul 31, 2001 | 07:06 AM
nm's Avatar
nm
yes, the one in the sticky is the 039A and this one is the B
Old Jul 31, 2001 | 09:54 AM
maximadave's Avatar
detailerdaveb@gmail.com
I have a friend of mine here in so cal that replaced both tcm's and put on my Unorthodox underdrive pulley at the same time, what a difference.
Maximadave
Old Jul 31, 2001 | 08:27 PM
azylstra's Avatar
I believe the reason for the TSB revision must be the new solenoid, the A bulletin called for 85X03, however that part has been replaced by 85X04, I think that's enough to trigger a revised bulletin. Also the date of the B bulletin is March 2001, around the time the new solenoids were introduced. Fortunately I waited until May to get the solenoids done and got the 85X04. I wonder about the people that got the 85X03 solenoids, are they eligible for another replacement or is it tough luck? The bulletin should clarify this, so it would be nice if someone could get it and post it. Another odd thing, NHTSA lists the bulletin for the Maxima but not I30.
Old Aug 1, 2001 | 12:19 AM
Menasor's Avatar
Maximadave
Where in So Cal did he get it done?
Old Aug 1, 2001 | 06:03 AM
jnm2kse's Avatar
I had my TCM replaced way back when the first slippage problems occured, way before the solenoid TSB. Now that I ma driving 180 miles a day with a good portion of that in stop and go I've noticed a few things....
when I'm slowly coasting and then give it a bit of gas, the engine will rev a bit and them slam and I mean slam into gear...is this slippage that I need checked or is the car perhaps being in a higher(2nd) gear and downshifting hard into first? I get some power and acceleration right before it slams into gear...to me it seems like the tranny is stuck in a higher gear and then is downshifting real hard but I might be wrong...
I've heard that if you don't come to a complete stop that the car will sometimes hang in a higher gear and then downshift violently when you apply the juice....true?
Old Aug 1, 2001 | 07:14 AM
Paul6speed's Avatar
Mine was the same way. I got the new TCM and it helped a little. After I got the new solenoid (85X03) it eliminated all problems.
Old Aug 1, 2001 | 07:46 AM
UMD_MaxSE's Avatar
Got Bent?
I have the 85X03 solenoids also.... I wonder what the difference is between these and the X04 solenoids
Old Aug 1, 2001 | 08:13 AM
Paul6speed's Avatar
I hope it's minimal. Maybe they scaled back the firmness. 85X03 are the hi performance version.
Old Aug 1, 2001 | 09:23 AM
UMD_MaxSE's Avatar
Got Bent?
hehehe... maybe, my shifts are pretty quick, especially from 2-3
Old Aug 1, 2001 | 10:04 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Guys,
You should seriously consider some sort of class action lawsuit. Nissan should be hung out on this one. They tried to be cheap by tweaking instead of strengthening a tranny that would have 32 ponies added on.....really sad....
Old Aug 1, 2001 | 10:11 AM
Paul6speed's Avatar
I thought about it when it occured. They've fixed the problem though and under warranty. They gave me a free rental, so what damages could I seek?
Originally posted by bill99gxe
Guys,
Old Aug 1, 2001 | 10:53 AM
bill99gxe's Avatar
My opinion:
These "fixes" are nothing but patches until the 60k powertrain warranty is up......after that Nissan can tell you all to fix it yourself.....
I hope I'm wrong, but when you have solenoid issues, TCM issues, you are sooner or later gonna have entire tranny issues.......this already with less than 20 or 30k on most of your cars!
Damages to seek: a new transmission
Old Aug 1, 2001 | 02:11 PM
Paul6speed's Avatar
Hmmm.... I don't know. The solenoid fix was for real. It changed the transmission performance greatly. In the TSB they instruct dealers to replace the transmission if metal shavings are found. None were found in my case. (Last year) I think Nissan is taking reasonable action on this. I don't think a class action suit will go anywhere. Nissan had a problem and they fixed it.
My opinion:
Old Aug 1, 2001 | 03:22 PM
LoveSick's Avatar
Guys,
Man, just look at Kev with close to 300hp grinding his automagic!
Old Aug 1, 2001 | 09:05 PM
Y2KevSE's Avatar
Testing out Don's VB.
Old Aug 1, 2001 | 09:18 PM
MaineI30's Avatar
Guys,
Yah man, when in doubt, sue sue sue.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
