ShoCKS
Old Aug 1, 2001 | 02:28 PM
MaDxKiLLa's Avatar
I was wondering if you get H&R sport springs will our stock shocks be okay? If not how much time do u tink ill have before stock shocks fail....i dun wanna buy new shocks and springs costs so much!!!
Old Aug 1, 2001 | 02:45 PM
Mustang1999's Avatar
Your stock shocks won't be able to handle the load. You might as well change the shocks while you are in there. I just bought my shocks yesterday and I have H&R sport springs waiting to be put on. I think with KYB AGX shocks the total came to about $6-700. I wouldn't recommend stock shocks with aftermarket springs.
Old Aug 1, 2001 | 03:17 PM
LoveSick's Avatar
if you have an SE, you might be able use the stock shocks for a year, but after that, the tokico get trashed easily.
if you have gxe or gle, dont even think about using H&R with it.
Old Aug 1, 2001 | 03:26 PM
MaDxKiLLa's Avatar
i have SE but oh nooo the moneyyyyyy goshhhh
Old Aug 1, 2001 | 04:01 PM
UMD_MaxSE's Avatar
Got Bent?
if you are getting new springs, you may as well do the shocks at the same time. It isn't worth it to do two suspension jobs. I am going to wait to see if the KYB's come out for the 5th gen....
Old Aug 1, 2001 | 04:15 PM
MaxTuner's Avatar
JIC coil-over
Old Aug 1, 2001 | 04:24 PM
DooBall's Avatar
check out shox.com
i got my H&R's and Tokico's for $575 (a little over $600 w/ shipping)
installation was $190, and $40 alignment (some say you dont need the alignment, but my car was leaning to the left)
Old Aug 1, 2001 | 06:14 PM
Chillboy
DO NOT put in the springs only! i have an SE and i put my eibachs without any struts. well, its been about 10k since and my SE struts are almost dead. i am definitely going to have to buy struts soon and spend an extra 150-180 installing the struts. shouldve done it together, oh well.
Old Aug 1, 2001 | 06:34 PM
UMD_MaxSE's Avatar
Got Bent?
Originally posted by MaxTuner
JIC coil-over
got more info on those?..... like if they will be available soon?
Old Aug 3, 2001 | 08:20 AM
MaDxKiLLa's Avatar
what will happen if u drive wid H&R too long wid stock shocks? Anything bad happen????
Old Aug 3, 2001 | 08:34 AM
UMD_MaxSE's Avatar
Got Bent?
the stock shocks will wear out...
Old Aug 3, 2001 | 11:39 AM
MaDxKiLLa's Avatar
what will happen if they wear out
Old Aug 3, 2001 | 12:14 PM
UMD_MaxSE's Avatar
Got Bent?
it will feel bouncy
Old Aug 3, 2001 | 12:44 PM
y2KAOSMax's Avatar
I'm hearing alot about the KYB's lately. Are they that good? Better that tokico's?
Old Aug 3, 2001 | 12:50 PM
UMD_MaxSE's Avatar
Got Bent?
they should last a longer than the tokicos... plus the KYB AGX are adjustable. You can actually adjust them while they are still installed on the car. Konis are good also, but you need to take them off, stick them in a vice, and then adjust them...
Old Aug 3, 2001 | 02:54 PM
y2KAOSMax's Avatar
Ok sounds good, do you know if they'll be more costly that the tokicos or Koni's?
Old Aug 3, 2001 | 03:06 PM
UMD_MaxSE's Avatar
Got Bent?
They probably more expensive than Tokicos but slightly cheaper than Konis. But, I got word from KYB that the shocks for the 5th gen will be available late fall of this year. I don't know if it is worth waiting that long.... I may just get the Konis. The Konis will probably last the longest anyways.
Old Aug 3, 2001 | 04:26 PM
MaDxKiLLa's Avatar
what wrong wid a little bouncy?
Old Aug 3, 2001 | 06:07 PM
MaDxKiLLa's Avatar
i heard u dun need shocks wid H&R since its only a small drop! i have to know for sure if its ok.......
Old Aug 3, 2001 | 06:38 PM
UMD_MaxSE's Avatar
Got Bent?
H&R's are forgiving and they probably don't put too much stress on the shocks anyways. You could probably get by with H&R's and stock shocks....
Old Aug 3, 2001 | 06:41 PM
MaDxKiLLa's Avatar
would RSB FSTB lessen stress on shocks?
Old Aug 3, 2001 | 06:50 PM
UMD_MaxSE's Avatar
Got Bent?
no.... I don't think so. They may actually put a little more stress on the suspension....but probably not too much I think.
Old Aug 3, 2001 | 07:23 PM
AznWontonboy's Avatar
if i remember correctly, i thought it was macpherson..
Old Aug 4, 2001 | 06:18 AM
UMD_MaxSE's Avatar
Got Bent?
macpherson is the type of strut setup..... not a brand. The stock SE struts are made by Tokico...
Old Aug 4, 2001 | 12:30 PM
irvine78's Avatar
oh please...that SE pride thang again..
nah, my stock shocks were good enough for a 1 year with my eibachs(they are still not blown by the way...), i just changed them with tokicos cuz i thought the shocks were getting little bit softer....
i should've gotten the Konis but oh wellz....
get the shocks and springs at the same time. just because you don't have to pay twice for the suspension mod.
Old Aug 13, 2001 | 08:57 PM
VQdriver's Avatar
irvine, how long have you had your tokico blues for? i just bought a 6 month old used pair of tokicos and eibachs. i figure for the price i midest well buy it. is it truly a good setup with durability? anyone with other comments?
Old Aug 13, 2001 | 10:23 PM
forgive me if i psoted this before, but the US 5th gens have macpherson struts boyyyyyyyy.
Old Aug 13, 2001 | 11:04 PM
Menasor's Avatar
I thought that the maxima had struts and not shocks. How can you fit shocks when have struts? Someone please enlighten me. Also I thought Mcpherson was also a brand since i seen them advertised many at tire shops.
Old Aug 14, 2001 | 04:38 AM
UMD_MaxSE's Avatar
Got Bent?
McPherson is the type of strut assembly... not a brand. I think the front suspension on the maxima uses struts, while the rear uses shocks.... the two terms are used interchangeably though most of the time....
Old Aug 14, 2001 | 03:37 PM
Menasor's Avatar
I'm not positive on this one but i think front and rear are all struts. i looked in the koni websites and seen pics of shocks and not struts for the 5th gen maximas. Confused as to how they would fit.
Old Aug 14, 2001 | 05:42 PM
UMD_MaxSE's Avatar
Got Bent?
The koni fronts are cartridges that are mounted in the stock strut housing. The rear are plain bolt on....
Old Aug 15, 2001 | 12:18 AM
Menasor's Avatar
So the cartriges go in the middle of the strut housing or something like? I'll have to check the their site. Pretty interesting. Mcpherson is not a brand name then and it would explaind why i hear monroe Mcpherson struts...Thanks for the info.
Old Aug 15, 2001 | 04:37 AM
UMD_MaxSE's Avatar
Got Bent?
check the installation/how-to sticky thread at the top.... I think the last post in there has instructions on how to install Konis
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Stagnet04
Sep 14, 2015 11:28 PM
