FSTB Install Problem - Stripped Stud
Bad news -- I stripped one brace nut during my Stillen FSTB install on my Y2K SE. Can't understand why -- I was torquing to 35 ft lbs per the factory manual. If I had used Stillen's recommended 43+ ft lbs, I might have taken out more than one. Anyone else experience this?
I can't tell if the nut or the stud is stripped, plus the nut does not want to come off. Oh well! I just happen to have a set of Tokico struts on-hand. Guess I'll move up my install date and change out offending assembly at the same time. I do have a 1,500 mile road trip first, so I'll keep an eye on the 'bad nut.'
Stripped Nut! - Good News & a Fix
Good news on this one. The metal in the nut is softer than the strut tower stud. I broke the offending nut off w/ a nut splitter (Ouch!) and ran a 10mm x 1.25 die down the stud to clean out the threads. I reinstalled the FSTB brace and torqued a new nut on the cleaned up stud to the factory spec (35 ft lbs). Note that the most common die if you have a Tap & Die set is 10mm X 1.50 (diffenet thread spacing), so make sure have the correct size die.
Lakersallday24
Nov 7, 2024 07:31 PM
kirkhilles
Aug 8, 2015 10:53 AM
