Cattman Y-Pipe Installed.... I'm tired!!!
Well I took on the job of installing the Cattman Y-Pipe myself since I figured myself to be a rather good Weekend Mechanic. Here is how it went...
The fit and finish of the pipe is EXCEPTIONAL, no doubt about that... However, the bolt holes on the flanges were not even close to matching up to the studs on the headers! I thought for a second that I was going to have to send back the pipe. Instead, I ran down to the local hardware store and purchased a DREMEL to round out the holes. After 1 1/2 hrs of grinding, the pipe finally gave in and I bolted everything up. Total install time 3 1/2 hrs. I've heard of variations from car-to-car as far as specs... but Sheeeesh!!!! I thought it would never end!!!!
By the way... I LOVE IT!
Congrats dude! My total install time was 3 1/2 days!
When I installed mine a month or so ago, it fit perfectly. I found that the hardest thing was after getting all the rusty bolts/nuts off was actually removing the pipe, I had to use my trusty rubber mallet sp? to help out. But I love mine too, something is hypnotic sp? about it's sound.
What?? Why do you say that the fit and finish is great on the pipe when you had to dremel the damn thing to get it to fit right? My stupid stillen pipe is not made correctly either, one of the hangers is cut off because it did not line up properly. Sometimes it seems like people design products and don't test them on the actual cars.
Ohhhhh... I do have a question for you guys, though. After installing the Y-Pipe, I noticed that the stock muffler doesn't quite hang the same way it used to. It now seems to hang a bit closer to the rear bumper. Has anyone else noticed this, or is it just my pipe that caused this?
congrats man! The fit with my cattman pipe was tight, but everything lined up just fine. It took a little pushing and a little crow-bar action to get it in there, but the fit and finish was great. As for the muffler hanging different, some people have noticed that. Mine is still just the same though
Originally posted by MAX2000JP
Mine does that too....I installed mine last week and noticed that the tip on the stock muffler is a little raised on the left side. Anyone know of an easy fix for this?
So what do you think is the final verdict on the Y pipe? I love my mod but am a little suprised that Cattmann and Stillen can't make the thing correctly. Oh, and what's the porterfield R45 in your signature?
I installed Porterfield brake pads on my car 2 weekends ago.... the car stops on a DIME!!! I recommend them to every Maxima owner. I got them for $118 for the whole set, thanks to MaximaDriver.com.
Ah haaaa... I think I know why it does that now. It appears that flange on the y-pipe that mates up to the cat is in a different position than the one on the stock y-pipe [slightly rotated]. I think this twists the b-pipe and rear section so that it does not sit as it used to.... hmmmm. Maybe when I get my RT cat [w/ rotatable flanges] this problem will be solved. I'm absolutely LOVING the sound of the muffler now... it seems to have gotten progressively more audible after the y-pipe install on Saturday. I gotta get rid of the crappy b-pipe, though.... I noticed that there is a HUGE crimp in it right after the resonator... reducing the size of the pipe to damn near HALF!
Be careful It gets WAY LOUD if you remove the resonator.
Also there is not much space over the axle so the pipe gets pinched down there also
Best regards,
Fast Walker
