unplugging the battery
Old Aug 25, 2001 | 08:57 AM
ecko's Avatar
how do u unplug the battery?
Old Aug 25, 2001 | 09:04 AM
clee130's Avatar
There's a nut on the connectors, just unscrew those and the connectors will come off.
Old Aug 25, 2001 | 09:05 AM
UMD_MaxSE's Avatar
Got Bent?
Do you want to remove it, or just cut power? If you just want to cut the power, then take a wrench and unscrew the nut that holds in the wire for the negative terminal (the one without the red plastic cover). Pull up once the bolt is loose and you are done.
Old Aug 25, 2001 | 09:42 AM
DooBall's Avatar
anyone else have this problem... the nut is too far in and surrounded by its surroundings...
no wrench, pliar, or vise grip can get a good grip =\
any ideas?
Old Aug 25, 2001 | 10:07 AM
UMD_MaxSE's Avatar
Got Bent?
a small adjustable wrench always works for me
Old Aug 25, 2001 | 10:35 AM
MaineI30's Avatar
any ideas?
Dude I can tell by looking at that pic that I could get that off with one of my wrenches.
Not trying to be a jerk, but .. it should be relatively easy if you get a decent wrench.
Old Aug 25, 2001 | 12:16 PM
DooBall's Avatar
thats the thing, i dont have tools =\
my dad stole them all and took them to his store... im left with whatever i find on the floor
and i had a small 10mm wrench (which i thought was going to work), but i had no room to turn it in either direction. that metal part at the end of the wires stick out too much
Old Aug 25, 2001 | 01:14 PM
TarHeelMax's Avatar
Voila! You've found the solution to your problem. You need to get your tools back.
Old Aug 25, 2001 | 04:27 PM
UMD_MaxSE's Avatar
Got Bent?
.... or ge yourself a 10mm deep socket
UMD_MaxSE's Avatar
Got Bent?
.... or get yourself a 10mm deep socket
Old Aug 26, 2001 | 02:46 AM
melanthius's Avatar
I believe i saw an infomercial for a product called the "gator grip" LOL
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
bigfrank
Oct 1, 2015 12:51 PM
