RSB installed..FST brace next?
Old Aug 27, 2001 | 10:26 AM
JWW's Avatar
JWW
Installed Stillen RSB and cornering is flatter. Car may have a little whip on highway over road imperfections...could be my imagination. Anyway, even tho my '01 SE is only a few months old do you gentlemen on this list feel I'd benefit adding the FST brace? I assume it will create a sharper turn-in...not sure what else I will experience. Has anybody first installed the RSB and THEN the FST brace? Appreciate you input.
Oh, BTW, install is a tad different from Paul Stauffers's directions, which are excellent. ABS sensor cable is no longer behind a metal shield along trailing arm. Instead, it is exposed and is attached to a thin, 1 inch piece of stamped metal or bracket that sticks out perpendicular to trailing arm. Pulled the rubber tie holding the cable out, bent the bracket down against trailing arm and placed the blue Stillen brackets over it. Seems to have worked fine.
Old Aug 27, 2001 | 11:08 AM
UMD_MaxSE's Avatar
Got Bent?
Yes... FSTB + RSB is a good combination... go fir it
Old Aug 27, 2001 | 12:08 PM
mbcp_tdogg's Avatar
I noticed a much greater difference after installing the RSB than the FSTB but in the general scheme of keeping your car nice and tight, the FSTB does help out greatly. I agree with UMD, do it.
I had the same install for the RSB as well.
Old Aug 27, 2001 | 03:17 PM
MaDxKiLLa's Avatar
im getting my RSB installed soon...i dun tink i can do it myself...i suck wid mechanical stuff..do you guys know how much itll cost for install of RSB and springs...
Old Aug 27, 2001 | 03:48 PM
clee130's Avatar
Do the RSB install yourself. Just need some wrenchs, two jacks (or ramps) and possibly a friend... And some beers for afterwards.
Old Aug 27, 2001 | 06:00 PM
MaineI30's Avatar
both
rsb and fstb are a great combination.
the rstb is a waste of time and money IMHO, especially since it is such a PITA to put on
Old Aug 27, 2001 | 07:22 PM
mdeal's Avatar
MaDxKiLLa, I would recommend you try it yourself if you have the tools. I don't think anything can go wrong except it fall off while driving down the road. Maybe somebody in Maryland can pitch in and guide/help you...
Old Aug 27, 2001 | 08:13 PM
cobymoby's Avatar
And if it falls off I'll run out into the street and grab it ha ha!
Old Aug 27, 2001 | 10:38 PM
ToYLeT902's Avatar
JET Speed Lab
at first i noticed my fstb, but now i dont notice it and it seems like its not even there anymore, maybe i've been turning too hard or expecting too much?
Old Aug 28, 2001 | 02:55 AM
melanthius's Avatar
Re: both
I agree, especially since the RSTB partially blocks the entrance to the 60/40 fold down rear seats! That's just STUPID! But I think you'd benefit from the FSTB and RSB.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Stagnet04
Sep 14, 2015 11:28 PM
MaxStock
Aug 14, 2015 10:01 PM
