AE 5 speed shift knob
Old Sep 10, 2001 | 09:27 AM
madmax2k1's Avatar
I just bought the AE 5 speed shift ****, and my question is regarding installation; How hard is it to remove the stock shift **** without damaging it, I heard that's it's actually glued with loctite to the shaft. Is that true ? I'm thinking of wrapping the **** with a towel and twisting it with some wrench, is that enough ?
Once I take it off, would the AE **** just screw on, or would I need some glue lock it in place ?
Old Sep 10, 2001 | 11:03 AM
MOBOY's Avatar
Use a strap wrench
If you have a strap wrench you should use that instead of vice grips.
I used a vice grip on mine and it took quite a bit of effort. I wrapped the shifter with a sock but still got a little scuffing on the leather. Try twisting the shifter off by your hand first. I am not sure if the AE **** will need to be glued. I would dry fit first and see if it is needed. I would only use glue if it is absolutely neccessary.
Old Sep 10, 2001 | 12:08 PM
dgraff's Avatar
Use your hands
I got mine off pretty easily by hand. Just let the car sit in the hot sun for a few hours, which will loosen up the glue. Then just twist it with all your might. A towel may help you get a better grip.
Old Sep 10, 2001 | 03:09 PM
Gary95's Avatar
a word of caution
I bought the AE shift **** for my '95 SE, and have had it installed for about 5 months now. It's not quite as well made as you'd think. The top portion scratches VERY easily. It's starting to look rather ****ty, actually. Wherever a scratch occurs, shiny aluminum shows through. I'm going to try coating it with a Krylon matte clear coat, to see if I can stop it from getting worse. But overall, I'm VERY disappointed with the quality of this product. My next step is to contact Nissan and complain.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
atriuum
Sep 28, 2015 01:19 PM
