Y2Kevse. How do you like those 300z
Old Sep 13, 2001 | 11:07 AM
Jeff92se's Avatar
I'm needing a caw
brakes still? I think I've asked this before. You still like them? Have you noticed alot more pedal travel?
Old Sep 13, 2001 | 11:22 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Yup, I still like them. I've gotten used to the brakes so they don't seem that impressive anymore... but when I drive Jane's car (Stillen x-drilled, Metal Matrixx, and SS lines) then go back to driving mine, I appreciate them again.
Pedal travel hasn't changed since the start... still have to go down a bit futher.
Old Sep 13, 2001 | 11:26 AM
Jeff92se's Avatar
I'm needing a caw
Thanks.
My brother wants to upgrade his brakes on his Villager! LOL.
I can understand though. I think those things weigh 3,500 lbs.+ but use the same crappy maxima brakes. He wants to fit some 300z wheels/brakes. hehe. modded mini-van.
Old Sep 13, 2001 | 11:29 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Originally posted by Jeff92se
Thanks.
Now that's what I call a ******* WAGON.
Old Sep 13, 2001 | 11:53 AM
Y2KevSE's Avatar
Thanks.
Now tell him to drop a turbo in there and run 11's all day long.
Old Sep 13, 2001 | 12:01 PM
BigDogJonx's Avatar
KEV, Always been wanting to ask you HOW MUCH did this setup cost you and was it a difficult install? I want to do it but a friend of mine tells me I would have to get rid of the 17" chrome wheels cause they wont clear the new brakes. Is that true?
I will do it for sure if I can keep my rims. I guess I can try to find the whole setup from a junk yard or something.
Old Sep 13, 2001 | 12:05 PM
UMD_MaxSE's Avatar
Got Bent?
just goes to show you.... people will mod anything
Old Sep 13, 2001 | 12:09 PM
Jeff92se's Avatar
I'm needing a caw
Yeah but this is a safety mod. Not for HP or rice factor.
Old Sep 13, 2001 | 12:19 PM
Y2KevSE's Avatar
It probably costs around $400-$500 (calipers, rebuilt kit, rotors, pads, SS lines, fluid)... I don't remember the exact number. The only major problem with doing this install is the clearance issue. You have to make sure the current wheels will clear or else you will have to use spacers (H&R has them).
Turbo95Max got me a set from http://www.autogator.com There are different types of calipers... aluminum or iron. Try to get aluminum because they are MUCH lighter.
Install isn't that hard. I believe http://www.maximadriver.com has a write-up (not positive).
Old Sep 13, 2001 | 12:22 PM
Colonel's Avatar
Old Fuddy Duddy
You have to make sure the clearance of the ID by the hub is going to clear the beefier brake calipers. I have not seen specifications on the 300Z, but have them for the Stillen Calipers. From center of hub the extend 7.436". From outside face of rotor at hub it extends 1.424" towards the outside area. From the back side of this same point (front face of rotor by hub) it extends towards the frame/engine by 4.261". I had factory 17" and no dice. Had to have rim speced out by Paul at Avalon to see if it would fit.
Old Sep 13, 2001 | 01:04 PM
UMD_MaxSE's Avatar
Got Bent?
i know.... but still
Old Sep 13, 2001 | 01:18 PM
Y2KevSE's Avatar
Isn't turbocharging a safety mod also? You need pass up all the slowpokes trying to merge into your lane, right?
Old Sep 13, 2001 | 01:26 PM
Jeff92se's Avatar
I'm needing a caw
Uh yeah, that's it! Safety first!
Old Sep 13, 2001 | 02:04 PM
xtantmaxima's Avatar
stillen big brake STILL for sale.
Old Sep 13, 2001 | 02:08 PM
UMD_MaxSE's Avatar
Got Bent?
safety first!
maybe the NHTSA can be pressed to give everyone boost
Old Sep 13, 2001 | 02:18 PM
yongjun's Avatar
Did i mention our family quest has a pop charger
hehe
Old Sep 13, 2001 | 08:52 PM
2001SE's Avatar
Kev how many miles you've got on your car?
Old Sep 13, 2001 | 10:49 PM
Y2KevSE's Avatar
Exactly 44,800
CHAZMAX
Jan 29, 2003 07:14 AM
Ironlord
Jul 20, 2002 06:43 PM
SmithAtlanta
Jul 3, 2002 05:01 AM
JPMontoya
23
Apr 16, 2002 04:59 PM
