19" rims and tires on a 2002 SE
Old Sep 24, 2001 | 07:40 PM
Stereodude's Avatar
I'm planning on getting a 2002 Maxima SE 6 speed with the HLSD as soon as they are available and I'm thinking ahead to what rims to put on it. I like the Moda R6's that tirerack has (19x8). Anyhow tirerack recommends 235/35-19 which will have the speedo 1.46% fast. The 245/35-19 (which they don't recommend) will only have the speedo .41% fast.
Will a 245/35-19 fit on a 2002 Max without rubbing in turns? I realize it's 2cm wider than the stock tire, but it this really going to be a problem? They recommend one that's 1cm wider than stock.
Stereodude
Old Sep 24, 2001 | 08:46 PM
rocketshipon19"'s Avatar
Re: 19" rims and tires on a 2002 SE
To be on the safe side roll w/ the 235/35. That is what I use!
Stereodude
Old Sep 24, 2001 | 09:22 PM
max'n out's Avatar
get as much tire as possible 245 or 255 there fit
Old Sep 24, 2001 | 09:34 PM
Cisco's Avatar
Just saw the new 2002 Maxima, and noticed that the 17's much larger; they look like 18's or even 19's. Anyone notice that?
GC
Old Sep 24, 2001 | 10:19 PM
i•maxx's Avatar
GC
How?…Wider or Taller?
Old Sep 24, 2001 | 10:22 PM
Cisco's Avatar
Rim looks larger, and the sidewall just looks a little taller, giving the impression of a larger wheel.
Old Sep 24, 2001 | 10:26 PM
freeze2k2's Avatar
I got the 235's
Old Sep 24, 2001 | 11:18 PM
BigDogJonx's Avatar
245s will be just fine.... No rubbing as long as the correct offset is chosen.
Dixit
Old Sep 24, 2001 | 11:27 PM
AznWontonboy's Avatar
GC
probally a bigger lip
Old Sep 25, 2001 | 02:35 AM
mbcp_tdogg's Avatar
Hmmm...they look the same to me. Just no center caps.
Old Sep 25, 2001 | 09:03 AM
Stereodude's Avatar
Dixit
So how do I know if the rims have the right offset for 245's? I don't want to look like some ghetto ricer who's got rims that extend past the wheelwells.
Stereodude
Old Sep 25, 2001 | 09:29 AM
maximawanabee's Avatar
OPTICAL ILLUSION
Those spokes radiating from the center give the illusion of making the wheel larger (as in taller) than what it actually is.
Old Sep 25, 2001 | 09:31 AM
The proper offset is 38mm. Nothing larger than a 45mm. I got some brand new 19" 235/35 Michelin Pilots that I can sell you very resonable!
Stereodude
Old Sep 25, 2001 | 10:18 AM
freeze2k2's Avatar
you can go with a 8" wide rim and 35-40 offset. If you go with an 8.5 wide you better have a 40 offset.
Old Sep 25, 2001 | 10:39 AM
max'n out's Avatar
get a 245-35 with a 39mm offset on an 19 x8.5 it will be fine
Old Sep 25, 2001 | 11:39 AM
Hey Jayson, I like the way that your radio uses the stock face as a false panel. How much did the installer charge you to do it? I noticed that you were wanting a grill, I am selling both of Street Concept grills for 200.00. They are still in the box!
Old Sep 25, 2001 | 03:51 PM
My 4DSC
I had 245/35/19 on my 2000 Max (same as 2002 i suppose)...
On 19x8 rims with a 40mm offset...
The rear would rub slightly on bumps causing a minor scrape.
But thats about it...
Old Sep 25, 2001 | 04:27 PM
Stereodude's Avatar
Aha, that's what I was looking for. I don't want any scraping, so it looks like 245's are out. Anyone have 235/35-19's that scrape?
Stereodude
Old Sep 25, 2001 | 08:39 PM
max'n out's Avatar
Thanks, I cound't begin to tell you want that peice cost alone...everything was dun at the same time then some things where changed or moded more... keep in mind once you rip it apart it don't go back together so you can't put the factory radio back in at all unless you get a new 1,000 factory radio.
I'm not sure if that is the grill I want or not...i may just end up making exactly what i want but at this point i just don't know.
Old Sep 26, 2001 | 08:43 AM
psing23's Avatar
for 18x7.5 is 40mm or 42mm offset good or too much? will it be coming out at all?
i want a 18x7.5 with a 235x40x18
that wont stick out or rub or anything right?
Old Sep 26, 2001 | 09:40 AM
I have the 235/35 19" and they have never rubbed!
Old Sep 26, 2001 | 12:08 PM
freeze2k2's Avatar
with a 7.5 rim I would use a 35 offset.
Old Sep 26, 2001 | 01:09 PM
Stereodude's Avatar
How do you guys know these numbers? Is there some reference material somewhere or does it just come with experience?
Stereodude
Old Sep 26, 2001 | 05:17 PM
QUINCY STEWART's Avatar
Stereodude
You could run a 235/40/19 and keep the factory ride.
Old Sep 26, 2001 | 06:16 PM
mbcp_tdogg's Avatar
That's pretty much what I have. So far so good.
Old Sep 26, 2001 | 06:20 PM
psing23's Avatar
how are the kumhos... those are the tires i wanna get too... do u like them? lemme know
also what offset are ur rims... lemme know
thanks
-danny
Old Sep 26, 2001 | 06:29 PM
mbcp_tdogg's Avatar
thanks
-danny
Although I haven't tested them too roughly, the Kumhos have held up pretty well so far. I'm able to make my sharp turns and other tasks with no problem. My offset's actually 45mm and they don't rub. I would consider getting 18X8 though because that'll help with the handling a bit more and the cost is usually not much more.
Old Sep 26, 2001 | 06:36 PM
psing23's Avatar
i found some nice rims that i like that are cheap but only come in 18x7.5
otherwise i would jump on the 18x8s for sure
Old Sep 26, 2001 | 08:49 PM
freeze2k2's Avatar
you could always use h&r hubcentric spacers to bring the wheels out a bit if you didnt like the way the 7.5's sat in.
Old Sep 26, 2001 | 09:01 PM
mbcp_tdogg's Avatar
I see. What rims did you find? How much?
Old Sep 27, 2001 | 07:18 AM
psing23's Avatar
at whalentire.com
they have a bunch of 18" rims for like $143 a rim... I like 3 rims from there but im not sure which to choose... i will call them up and find out which are the lightest...
the first 1 that i like is the ADR Design RS Limited IKARI in Gun Metal
the second 1 that i like is the ADR Design RS Limited TRAMA in Gun Metal
the third 1 that i like is the ADR Design RS Limited VALKYRIE in Gun Metal
these are all $143 per rim... so 4 rims is $572... but then they also have Kumho ECSTA Supra 712 for $129 each... so the package costs $1088 and it includes the wheels, tires, free mounting, balancing and valve stems... so i think its a good deal... and they look nice too... and i wanted dark rims cause of my grey lustre i think it will look dope... but the question is im not sure which to choose...
ikari
trama
valkyrie
Old Sep 27, 2001 | 08:06 AM
Cisco's Avatar
I dont know, but they look like knockoff's of Racing Hart's. I guess for that price, they are OK.
at whalentire.com
ikari
trama
valkyrie
Old Sep 27, 2001 | 08:15 AM
psing23's Avatar
SHHHH u cant speak... lol u got SSRs (my favorite rims of all) i dont allow u to speak in this thread...
Old Sep 27, 2001 | 08:17 AM
Keh mon's Avatar
Haha yeah they do look like RH, but these are definately cheaper. I have a grey lustre max too so when you get them take a lot of pic's I wanna see what dark rims would look like on our cars. I'd pick between the second and third rims you have pic's of.
Old Sep 27, 2001 | 08:22 AM
psing23's Avatar
ye i was leaning towards those too cause they have bolt covers... so it looks cleaner... but which to get... they are both nice... which do u think look bigger? the 2nd 1 is 40 offset and the last one is 42 offset... will they look different on the car? only 2mm... i dunno... i think i like the 5 stars...
people gimme ur opinions!! hehe
Old Sep 27, 2001 | 08:57 AM
psing23's Avatar
i just called them and they said they are all approximatly 25lbs a rim...
is that good? bad? average? for 18" rims? the stock ones are like 50lbs right?
Old Sep 27, 2001 | 10:14 AM
NYCe MaXiMa's Avatar
Psing...
I like #2 and #3....
25 lbs for a 18" rim is fair. Most 17s weigh around 22-24 lbs.
But, ADR are one of those knock-off brands.. Maybe you can spend an extra 30$ per rim or so and get something better... check out www.discounttiredirect.com they have lots of **** for sale right now.
Old Sep 27, 2001 | 10:15 AM
Re: Psing...
Here:
http://www.discounttiredirect.com/dt...=18&plusSize=3
Old Sep 27, 2001 | 10:21 AM
psing23's Avatar
what is wrong with the ADR wheels? are they really bad quality? what can i expect to happen to them in the long run? i mean they look good... but will they crack or break or something? does anyone have any experience with ADR rims?
Old Sep 27, 2001 | 11:06 AM
freeze2k2's Avatar
You get what you pay for.
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
