Scanner to Clock unit WIRING!
Old Oct 3, 2001 | 09:29 AM
BigDogJonx's Avatar
Now here is what the back of the clock unit looks like. If you look closely, you will see that EVERY wire is labeled and tells you what it is. All you have to do is hook it up to the correct corresponding wire.
Now this shows an exact picture of the wiring I have done. The RED wire from the SCANNER connects to the Yellow/Red wire. The YELLOW wire from the SCANNER connects to the Green Wire (The picture shows me splicing a black wire, that is because I had to extend the original yellow wire from the scanner.) The last wire left on the scanner is BLACK, that I just grounded to the sunroof bolt under the sunglass holder. No need to extend that wire all the way down to the clock unit for NO reason.
This will work and is the correct way to wire the scanner. It will blink or do whatever pattern when the car is off or armed. When the car is turned on, the scanner turns off.
Hope this helps and solves everyones problems. Simple install, but I think some of you got confused. Now everyone can have knightrider style SCANNERS.
Old Oct 3, 2001 | 09:45 AM
yongjun's Avatar
Re: Scanner to Clock unit WIRING!
WoW Good stuff man.
Time to add it to the sticky
Y2KevSE's Avatar
Rice Boy in Denial =)
Feel free to add this thread to the How-To, Dixit.
Old Oct 3, 2001 | 10:06 AM
BigDogJonx's Avatar
Damn did not know that thing was up there to post to. DONE!
Old Oct 3, 2001 | 10:12 AM
Y2KevSE's Avatar
Thanks!
Yup, anyone can post in there.
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
