what? another 2k2 light post?! have a 2k2?
Old Oct 10, 2001 | 10:05 AM
TimW's Avatar
The silent but deadly Moderator
riddle me this, as I havent spent much time with a 2k2. Do the lights have a delay when turning on? or a delay turning off? so they dont flash when being switched.
How bad is a few flashes to the ballasts?
Old Oct 10, 2001 | 10:50 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: what? another 2k2 light post?! have a 2k2?
I can answer part, but Hogan(yo_its_ok) will have to answer "How Bad Is Flickering the HIDs".
My HIDs do NOT flash. The HI-beams either turn on or off, but the HIDs remain lit. The only time the HIDs flash is when the ALARM is triggered(Should be fixed soon!) and when I switch from OFF over the AUTO switch postion to the running lamps to the NORMAL switch position. This can be fixed also by eliminating the AUTO light sensor, which again should be done soon.
Old Oct 10, 2001 | 05:44 PM
AznWontonboy's Avatar
what about those bmws dat turn there lights on and off and use them as high beams
Old Oct 10, 2001 | 07:37 PM
Keh mon's Avatar
Re: Re: what? another 2k2 light post?! have a 2k2?
Triggered as in when it goes off and NOT when it is set? Hopefully that's what you mean. Am I correct in saying that the lights are different than the 2k and the 2k1's in which the 2k2's do NOT turn off when the door is opened after the car is off? Meaning with the 2k2 we have to manually turn them off... maybe there's a way to have it so that we need to only use the parking lights for the day and the HID's etc, at night... then we don't need to flip through the auto part.
Old Oct 10, 2001 | 09:40 PM
bigbadboss101's Avatar
Stupid question: what does the daytime running light look? Is it whiter than normal?
Old Oct 10, 2001 | 10:16 PM
Maximum Velocity's Avatar
Looks like a regular stock clear bulb...on the yellowish side. Will look whiter with some aftermarket bulbs. I have the PIAA xtreme whites (wedge bulbs). I know others have Raybrigs.
Old Oct 10, 2001 | 10:20 PM
IceY2K1's Avatar
Re: Re: Re: what? another 2k2 light post?! have a 2k2?
Yes, when the ALARM is set off it flashes the HIDs. Only the turn signals flash when you ARM/DISARM.
The 2K2 will turn off when you open the door.
I'd rather have no running lamps and just DISABLE the AUTO feature.
Old Oct 11, 2001 | 08:30 AM
Keh mon's Avatar
Re: Re: Re: Re: what? another 2k2 light post?! have a 2k2?
Thanks for the info... yeah disabling the auto feature would be fine with me... or could we just switch the wires from the auto and the on positions?
Old Oct 11, 2001 | 08:44 AM
myktek's Avatar
Re: Re: Re: Re: Re: what? another 2k2 light post?! have a 2k2?
Thats what i said on a different post a few days ago. . .switch the auto to the last one. . .and move parking lights up next to off. . .then u would have. .
OFF - Parking Lights - ON - AUTO instead of what we have now
OFF - AUTO - Parking Lights - ON . . .
GREAT MINDS THINK ALIKE. . .hehehe
Old Oct 11, 2001 | 08:58 AM
Keh mon's Avatar
Re: Re: Re: Re: Re: Re: what? another 2k2 light post?! have a 2k2?
hehe yes they do. Now as long as I can ever understand all this relay crap. Sounds like I'll need to do it sometime, but it sounds too complicated for my non-EE mind to understand.
Old Oct 11, 2001 | 09:17 AM
IceY2K1's Avatar
Re: Re: Re: Re: Re: Re: Re: what? another 2k2 light post?! have a 2k2?
Sure, I'd like to switch the AUTO and ON postion, but HOW?
I believe it's not possible since it's all done INSIDE the Combination Switch and controlled by the SMART Control Unit. There isn't any way to do this as far as I can see. Maybe after I get ALL the other $hit figured out I might be able to "ghetto-rig" something, but for now unplugging the AUTO light sensor SEEMS the simplest solution. Plus I like to be able to turn on my running lamps without first turning on the HIDs. The less I turn on then off the HIDs the longer life expectancy they'll have and since the bulbs are going to be over $100 to replace that's my MAIN concern right now.
Samedi
Aug 13, 2015 04:05 PM
Flores94
Aug 11, 2015 12:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
silver_i35
Aug 3, 2015 11:23 PM
yat70458
Aug 3, 2015 01:16 PM
