2K2 Alarm Fix INSTALLED and WORKS Great!
Old Oct 11, 2001 | 05:53 PM
BigDogJonx's Avatar
Well After ICE, 2MaxGuy, and I been going buck wild on this freagin alarm fix. I decided to do it myself and do a slightly different version of what ICE and 2MaxGuy came up with.
First off let me explain what ICE and 2MaxGuy came up with, they were going to cut the relay trigger going to each headlamp relay (which is a PINK wire by the way). And then using a relay tap into the running light wire to activate the lights when the lights are turned on. I dont know how to fully explain the relay setup as it would be much easier to draw out, but they would now still use the pink wire they cut off but install a relay in the middle and use the running light power to power the relay, so TECHINCALLY when the alarm goes off, it DOES NOT blink the running lights, so the PINK wire can attempt to blink all it wants, it will never BLINK the XENONS.
BUT THE PROBLEM with that setup i noticed is that if you turn your running lights on, your XENONS turn on also, works fine, but if you are like me and want to keep the car original, and want the running light switch spot to be a running lights only, then this wont work.
ALL I did to solve this problem, is instead of tapping the running light power wire, I tapped a IGNITION Switched WIRE, which basically means when the ignition is in the ON position, then and then the headlights will turn on. So technically same relay setup except different power source for the relay. I actually TAPPED the RED/Gray wire off the O2 sensor I believe that is what it is.
So now my joint is working great and FINALLY the damn thing is fixed. Just got my headlight clips from DaveB and need to install them puppies now.
All tired now.
Dixit
Old Oct 11, 2001 | 06:17 PM
2maxguy's Avatar
Re: 2K2 Alarm Fix INSTALLED and WORKS Great!
Glad to hear it! What's next?
All tired now.
Dixit
Old Oct 11, 2001 | 06:18 PM
Keh mon's Avatar
All tired now.
Dixit
(I'm gonna be the first to say it.....)
WOO HOO!!!!!!! AWESOME JOB GUYS!!!!!
Old Oct 11, 2001 | 06:21 PM
2maxguy's Avatar
Old Oct 11, 2001 | 06:23 PM
BigDogJonx's Avatar
Well like I said, the clips are going on tommorow, and then I am going to sit back for a couple of weeks, cause then I am installing 3TVs in the car, that is gonna be FUN!
Old Oct 11, 2001 | 06:28 PM
Tanman's Avatar
Great job on fixing the alarm problem. One request that I (and I'm sure others like me who are not electricians) have, is that you do a detailed write-up of the fix. When you mention things like "the RED/Gray wire off the O2 sensor" or "IGNITION Switched WIRE", most of us have no idea where to locate that particular wire or how to get to it under the hood. If you have the time or inclination, could you post some pictures or diagrams with these wires labelled? I know it's not your job to educate us, but you stirred the pot, now we need the chef to teach us to cook.
Old Oct 11, 2001 | 06:58 PM
ohboiya's Avatar
Re: Re: 2K2 Alarm Fix INSTALLED and WORKS Great!
ditto dude!
Please update your site with detailed instructions!!!
TKX!!!!!!!!!!!!!!!
Old Oct 11, 2001 | 07:13 PM
BigDogJonx's Avatar
No problem, I will ATTEMPT to make a write up for you non-technical people.
I will take pictures and stuff tommorow and make the write-up. I would have taken them during the install but did not have the camera.
I have to install the clips tommorow anyways.
Dixit
Old Oct 11, 2001 | 07:58 PM
ohboiya's Avatar
Dixit
Muchos gracias!
Old Oct 11, 2001 | 08:34 PM
Tanman's Avatar
What kind of camera do you use? If it's a Sony that will use memory sticks, I'll mail you a 32MB stick you can snap some pictures with .
Old Oct 11, 2001 | 10:01 PM
BigDogJonx's Avatar
Yeah I do use a Sony Mavica. You want me to take pictures on the memory stick and then mail it back to you? Is that too time consuming and what not? Better easier if I just post them online, very small images. No more than 30-60k each.
Dixit
Old Oct 12, 2001 | 01:27 AM
Menasor's Avatar
I second that as well. Great Job guys! You guys are the org or the 5th gen light specialist. How long did it take to do this?
Old Oct 12, 2001 | 01:33 AM
BigDogJonx's Avatar
Re: Re: Re: 2K2 Alarm Fix INSTALLED and WORKS Great!
Once I get the writeup done, for those of you that have no clue what or how to do it, it will take no more than 30mins TOPS!.
Dixit
Old Oct 12, 2001 | 06:04 AM
Keh mon's Avatar
Re: Re: Re: Re: 2K2 Alarm Fix INSTALLED and WORKS Great!
Dixit
Wow you guys truely are amazing. I'm driving home today and I'd like to try to get them on (without relay's for now). BTW if I go with your install the HID's turn off the high beams? (the non-relay setup). Is there an easy way to change this? On your site it says they work, but then on posts I heard they don't stay on with the high's. I'm sorry for my electrical ignorance, just don't want to mess anything up.
Old Oct 12, 2001 | 06:52 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Nice!
Old Oct 12, 2001 | 07:08 AM
BigDogJonx's Avatar
Re: Re: Re: Re: Re: 2K2 Alarm Fix INSTALLED and WORKS Great!
No Keh Mon, I changed it. Look again in the writeup. All I did is change one wire, instead of taking the ground from the H4 plug for the Xenons, I took the ground straight to the body. No more Xenons turning off with the High beams anymore.
Very Simply. The Writeup has the change already.
Dixit
Old Oct 12, 2001 | 04:11 PM
Keh mon's Avatar
Re: Re: Re: Re: Re: Re: 2K2 Alarm Fix INSTALLED and WORKS Great!
Dixit
My bad. I think I get a little too carried away with my lazyness sometimes.
Tbone3944
Sep 29, 2015 09:04 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
