My Window SQUEKS!!!
Old Oct 16, 2001 | 06:51 PM
Raf2kMax's Avatar
My Window SQUEKS!!!
Whats up,
i have automatic windows and stuff and whenever i roll em down (my side and passenger side) it squeks LOUUUUUD from halfway down to all the way down. i roll em down all the time when i cruise around local roads and stuff...and the glass has 35% tints(not done from factory but properly done nonetheless).. think i should jus go to the dealer?? this should be covered in the warranty rite??
thanx in advance people
Old Oct 16, 2001 | 07:04 PM
WILLSE's Avatar
damn man me too sucks doesnt it! throw some crisco oil on it haha jk... i dunno if the dealer will cover it tint doesnt void the good ol warrenty! all the will do is grease it up! so i dunno let me know when u figure something out!
Old Oct 16, 2001 | 07:26 PM
BottleFedMax's Avatar
All you have to do is lube the window tracts with silicon spray and all the squeak will be gone However the squeak will eventually come back and you will have to lube again.
Old Oct 16, 2001 | 07:36 PM
TimW's Avatar
The silent but deadly Moderator
go to Napa..
and get something called "sil-glide" I forget the name, I have some, used it last weekend. basically, is silicone lube for rubber. it is for windows and door gaskets.
Wipe the tracks down with a wet towel to get the dirt off (often that alone is enough to stop the squeal). Spray some on the towel, then wipe on and into the tracks. Dont spray it directly onto the tracks and watch the overspray, it can discolor plastic or paint (its clear and i guess it would make 'wet looking' dots if left on paint). I do the max and pathfinder about every 6 months. The back door/hatch gasket squeaks on the PF, this helps ALOT there.
Old Oct 16, 2001 | 08:36 PM
maxgsxr1
i work at a infiniti dealer and we replace the window rubber guides all the time on the i30 which is the same as the max. if your car has under 36 k. bring it to the dealer.....they will replace them under warrenty.
Old Oct 16, 2001 | 09:00 PM
Green_2's Avatar
it's most likely what the above posts are saying...but sometimes it's the connection between the glass and the raise/lower rail thing...don't know what it is called, but you might have to take it into the dealer for some service if the lube doesn't work. It should be covered though, tint or no tint.
Old Oct 16, 2001 | 09:03 PM
Y2KMaxGXE-R's Avatar
yeah mine stopped squeeking after some silicon lube. However, when I lower my driver's window, It's making noises as if the mechanism is loose..anyone?
Old Oct 16, 2001 | 09:47 PM
Green_2's Avatar
Hehe...see post just above yours...
Old Oct 17, 2001 | 07:34 AM
Raf2kMax's Avatar
7 am saturday morning they told me to bring it in to the nissan service place so that they can check it out. if they start giving me a hard time, im gonna have to go buy the silicon lube stuff. hope it all goes smooth as planned. thanx alot guys.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
