Brake Warning and Charge (Battery) Warning Lights
Old Sep 17, 2007 | 09:49 PM
ramnrick's Avatar
I was driving when both the brake and charge (bettery) warning lights light up at the same time. I make sure handbrake is down and look for any interior lights flickering. Nothings seems out of the norm. Both warning lights stay on for a while in normal street driving and suddenly both warning lights go off. It goes on and off for a couple more miles when I finallys decide to pull over and pop the hood. Brake fluid is full. Battery connection is tight. Start up car and no more warning lights. Drive for about 12 miles and both warning lights come on just as I pull into my driveway. Any ideas?
Old Sep 17, 2007 | 10:04 PM
steven88's Avatar
Need A Light?
I heard that this is a sign of a bad alternator...when both of those lights stay on, then your alternator is on it's way out
Old Sep 18, 2007 | 12:33 AM
MaxBoost925's Avatar
Drug Money
Werd.
Welcome back OG.
Old Sep 18, 2007 | 09:35 AM
wngan9447's Avatar
Chicken Feet Croo!
On it's way out or completely out... my belt broke on my one day and those lights came on.
Old Sep 18, 2007 | 09:45 AM
Lovemycar's Avatar
Alternator is bad to be sure disconnect the negitive battary cable while the car is running if it shuts off you have a bad ALT
Old Sep 18, 2007 | 11:56 AM
SurraTT's Avatar
HR Swap Pioneer
BAD IDEA, unless u want to take a chance on your whole electrical system
get it tested @ ADVANCE AUTO
Old Sep 18, 2007 | 12:22 PM
ShiftVQ35
alternator....... It is pretty simple to figure it out.....
Old Sep 18, 2007 | 03:20 PM
ramnrick's Avatar
Alternator it is. Being replaced as I type. Just wanted to make sure. Thanks for the replies..
Old Sep 18, 2007 | 06:57 PM
justinny's Avatar
the best way to test your alternator is with a multimeter
it should read between 13.5 and 14.5 volts dc for best charging
start car and turn on everything electrical and crank the radio if it dips below 13 it might be on its way
also have your battery load tested to rule it out
alot of the time a bad alt will take out the battery
removing the cable from the battery is a very bad idea
the alternator's only job is to charge the battery not supply current to the vehicle
thats the battery's job
when you take the battery out of the picture the carbon brushes in the alternator burn up very fast (down to the tension springs and burns up the slip ring on the rotor)
and a good alternator can become a bad alternator very quickly due to that test
tsi6001
Oct 3, 2022 10:23 PM
Sport
Jul 3, 2017 05:40 PM
homeyclaus
Sep 3, 2015 06:15 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
