replaced the lights on the door with led's but have a little problem need help
Old Sep 23, 2007 | 11:13 AM
imported_D_Roc's Avatar
I recently replaced the bulbs on the door lights with LED's. 2LED's on each light with a 220ohm resistor, it looked great but for one problem. The lights stay on very dim (only visible at night) and is on only when the engine is off. I thought it will go away after a while but it stayed on the whole night so i replaced them with the old bulbs it didnt happen with the old bulbs so is it normal or did something went wrong only happened with the led's
thanks
D
Old Sep 23, 2007 | 11:18 AM
Memphis2k1's Avatar
Mine do the same. I bought some LED wedge style bulbs on ebay and they do stay on. And I think the same goes for my main interior light. Very dimly but I can tell a difference when on the main interior light when I set the switch to the off position
For me, I know it happens when I arm my alarm (locked).
Old Sep 23, 2007 | 11:57 AM
thanks guess maybe the led's can work on a very small voltage but what concerns me is that can it drain the battery?
Old Sep 23, 2007 | 12:03 PM
Maximized2000's Avatar
Thats strange. Make sure the door is closed tight. I have leds in my doors and I'm pretty sure they are not lit at night when I have all the doors closed and I hit the lock button.
Old Sep 23, 2007 | 12:26 PM
Onemax's Avatar
Same thing happend to me when I installed my door LED's. They stay on but are very dim. Also when I get in the car in the morning (it's pitch black out) my seatbelt light is on very dim too. I replaced the LED's with normal bulbs and the issue went away. Strange.
Old Sep 23, 2007 | 03:06 PM
OHH NOES's Avatar
6spd Swapped
It's called ground loop, in other words the bulbs you bought are cheap. Dont be lazy, do some research and make some custom LED boards to fit your lights.
Old Sep 23, 2007 | 04:00 PM
I made custom LED boards for mine so thats probably why I don't experience the same problem.
Old Sep 23, 2007 | 04:49 PM
i made my own there some pics of it but i bought the LED's off ebay 100 of them for $12 so guess the LED's are poor quality. the reason was the radioshack bulbs were too much and not that bright
King_Ten_Ahead
Sep 30, 2015 04:27 PM
spidgeon
Aug 18, 2015 05:46 AM
220k+ A32
Aug 17, 2015 03:57 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
