How much to replace front axle on 2000 SE?
Old Sep 24, 2007 | 06:40 PM
zoutv's Avatar
I have a 2000 SE, and the front axle needs to be replaced. Anyone have an idea of how much only the parts would cost?
Old Sep 24, 2007 | 07:14 PM
NmexMAX's Avatar
dot dot dot ...
$120 @ AutoZone w/ a 30$ core IIRC. Call them and ask.
Old Sep 24, 2007 | 07:24 PM
KRRZ350's Avatar
I've bought many from my favorite junkyard for $35, I found them on Car-part.com and they give me a 3-month warranty on axle's
Old Sep 24, 2007 | 07:27 PM
Professor's Avatar
Ltd Lifetime warranty , Advance Auto Parts, $69.99 $30 Core Rebuilt, $79.99 New no core.
Old Sep 24, 2007 | 07:34 PM
NmexMAX's Avatar
dot dot dot ...
Seems as if you have some leg work to do now.
Old Sep 24, 2007 | 08:45 PM
DrunkieTheBear's Avatar
Turbo'd Saab
www.raxles.com
/thread
Old Sep 24, 2007 | 08:46 PM
MaxBoost925's Avatar
Drug Money
Originally Posted by SilMax00
WERD!!!
Old Sep 24, 2007 | 08:51 PM
Turbo'd Saab
$150 per axle, they don't charge your CC for the core unless you don't return the core and great customer service and i believe there is a really good warranty with it.
and if you pay someone to install it (which I don't recomend you do), its like 2 hour labor charge.
Old Sep 24, 2007 | 08:56 PM
Drug Money
It takes me 15 minutes to do a axle.
Old Sep 24, 2007 | 09:12 PM
Turbo'd Saab
yea i know, but you just know a shop will charge 2 hours
Old Sep 25, 2007 | 03:52 AM
zoutv's Avatar
Well I just helped my shop fix one of those insane PC issues. It took about 4 hours to get the PC running right. So the shop owner decided to give me a 4 hour labor credit. To get the axel fixed will cost me just the parts.
Basically when ever I turn to the left in my max, there would be a soft clicking sound coming from the front left tire well.. Also, my steering wheel column is a bit 'soft.' In that when I turn the wheel there are parts where it seems to completely loose resistance...like its floating when turning left to right.......
Old Sep 25, 2007 | 07:00 AM
aznaliaz's Avatar
if u live around brooklyn, bring it to CosMo auto performance..
its on 4th ave and 33rd/32nd street. say jason refered ya
Old Sep 25, 2007 | 09:57 AM
CHINO22's Avatar
That clicking noise could sometimes just be that the plastic boot is crack and all the grease fell out so it causes the axle to loose lubricant..Maybe u just might need that done .That sometimes might cost as much as a new axle..Up to u
Old Sep 25, 2007 | 01:57 PM
KRRZ350's Avatar
Unless some idiot tightens some weird looking deffinitly not the original axle nut sooooo tight that with 5-ft of pipe you break a 1/2" drive ratchet and a breaker bar (both craftsmen) and you have to stop what your doing and head out to sears to get butt raped on a 3/4" drive socket and breaker bar......... Yeah, that was the story of my day today doing an engine on a '96 I30........
And I'm sure I'm not the only one who spent hours trying to pound/chisel out a passenger side from the support bracket only to later learn the trick of throwing a jack under the front header/y and undoing the entire support bracket........ But yeah, most of the time axles are amazingly easy and shops just overcharge.
Old Sep 25, 2007 | 06:51 PM
SilverGLE's Avatar
I'm watching you, boy...
2 hours of labor, about $60/hour, which is what I paid for both front axles.
Old Oct 1, 2007 | 10:44 PM
Vadim's Avatar
My car started making a clicking sound when turning left. It's coming from the right wheel. I took off the wheel and inspected the whole suspension. It was fine. I noticed the inner boot of the CV joint was a little wet by the smaller clamp. I can only think that it is the bad CV joint? can you guys confirm? and my rear motor mount is destroyed
Old Oct 2, 2007 | 04:37 AM
KRRZ350's Avatar
I don't think I've ever seen an a32 or a33a/b that DIDN'T have a torn rear motor mount, well I have but they love to chew them to ****. Get the es inserts and install them yourself, asides from the basics you'll need a sawzall, a few beers, a propane tourch, and a sledgehammer.
Sounds like the cv to me, if you grasp both sides of the joint you'll probably feel some play.
Old Oct 2, 2007 | 07:29 AM
Vadim's Avatar
Thanks KRRZ350! I know Place racing and ES mounts are all solid Polyurathane. Is there someone who makes something in between stock and polyurethane ones? can i just replace a rear one with a solid one and leave the fron stock? i guess i just don't want too much vibration at idle.
Old Oct 2, 2007 | 07:56 AM
KRRZ350's Avatar
IMHO the vibration at idle is barely noticable, it won't bother you one bit, but yes you could do just the rear, I don't know of anyone who makes one halfway between, but you could always buy a stock replacement on E-bay as well
Old Oct 2, 2007 | 09:42 AM
Vadim's Avatar
thanks! looks like i'm going to get the ES mounts off the ebay, they are $84 for a set of 2 with shipping. So, i'd torch the metal bracket and get the old one out and then hammer the new ones in? Soory for going a little OT guys
Old Oct 2, 2007 | 12:56 PM
KRRZ350's Avatar
I think it's all good, this guy appears to be all set.....
Actually, you torch the rubber, you don't have to completely torch it, just enough that the inner sleeve will come out and it gets all hard and crumbles really easy, you just need enough room that you can stick the sawzall blade inside the mount to cut through the metal sleeve, cut it where the hole is and try to keep it straight so you can see when you are through the sleeve (this will make sense when you are doing it) than the outer sleeve taps out easily, and yes, the sledgehammer is to tap the new one in. Basically, this saves you the hassle/time/expense of having to remove both mounts from the crossmember and bring them to your machinest and than have to pay him like $50 to press out the sleeves and press in the new bushings, you can always go that route as well, personally I think getting to use propane and power tools is more fun
Old Oct 2, 2007 | 01:59 PM
Vadim's Avatar
Thanks again! I ordered them and they should be in before the weekend
Old Oct 4, 2007 | 06:54 AM
Max_Gator's Avatar
I somehow cross threaded my original axle nut on the axle - don't ask me how since I hand threaded it. But your experience and mine pretty much match - broken breaker bars, couldn't get it off even with my high powered air tools, the shop had hell getting it off.
Old Oct 7, 2007 | 09:04 AM
geenowalker's Avatar
I am in the same spot (replacing the axles) as my boots are shredded. There is no clicking noise, but going into winter....may as well get it done. Are Raxles really worth the cash? $150 per plus shipping runs about 330 for both. I can get autozoned for about 150 (probably rebuilt). I am not racing the car and am questioning the logic of the raxles at this stage. Watcha think?
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
PH98I30
Aug 20, 2015 04:25 PM
Samedi
Aug 12, 2015 01:54 AM
jholley
Aug 11, 2015 09:38 AM
