Steering wheel shakes while breaking
Old Sep 24, 2007 | 08:05 PM
jasonmax's Avatar
My 02 Maxima GLE's steering wheel shakes while breaking, what's wrong with it? It's kinda left-right shake...
Old Sep 24, 2007 | 08:09 PM
AlpineGt66's Avatar
99.6% your front rotors are warped. I had the same problem until I switched out the front rotors.
Old Sep 24, 2007 | 08:13 PM
TurtleHead
You could get them turned if you still have enough left on them.
I had to get my turned about two years back because I had the same problem.
Stock Max rotors are not the best.
Old Sep 24, 2007 | 08:14 PM
doc2278's Avatar
Doctor D I presume???
Could be your CV axles.
Old Sep 24, 2007 | 08:20 PM
jasonmax's Avatar
It's a used car. I just wanna make sure everything is OK instead of breaking something.
Old Sep 24, 2007 | 08:21 PM
jasonmax's Avatar
Could it be the pads?
Old Sep 24, 2007 | 08:26 PM
MaxBoost925's Avatar
Drug Money
OEM pads ruined OEM rotors.
Old Sep 24, 2007 | 08:27 PM
SoonerFan's Avatar
Cletus
its "warped rotors" which is actually pad material transfered to your rotors. turning the rotors will remove the material. get better pads (hawk HPS) to prevent in the future
Old Sep 24, 2007 | 08:28 PM
CoolMax's Avatar
is invisible
It's a used car. I just wanna make sure everything is OK instead of braking something.
dited for consistency
btw, this is why we have the thread.
to what sooner said.
Old Sep 24, 2007 | 08:33 PM
jasonmax's Avatar
Sorry about that..some threads missed..
Old Sep 24, 2007 | 08:40 PM
Love_00_Max's Avatar
I found the best return on investment on steering wheel shake is rotors and sway bar endlinks and tie rods.
Sway bar ends and tie rods definetly is a source of steering wheel shake in high mileage vehicles as was in my case.
Old Sep 24, 2007 | 08:42 PM
jasonmax's Avatar
Mine just shakes while breaking.
DrunkieTheBear's Avatar
Turbo'd Saab
i just bought brembo blanks and hawk hps all for about 325...ebay can be a friend sometimes and car-stuff.com as well
Old Sep 24, 2007 | 08:46 PM
tonyw's Avatar
How may miles on your car? Rotors are cheap and easy to replace. I had mine turned under warranty and they warped again. I put new ones on and no more vibration....
Old Sep 24, 2007 | 08:53 PM
Turning rotors over is a waste of money becoz the rotors have mechanically deformed in one or more locations, it will warp at the same spot again even if turned. Good rotors like brembo blanks come cheap and a great investment, the stock ones were a piece of crap.
When I bought my car new, I wanted to keep it looking new forever, I made my stock rotors even more crappier/warped by taking those free car washes for filling up the tank (the free car washes are now a distant memory, all gas stations charge out here in CA). That is a definte NO NO when the rotors are hot.
Anyway, good luck as others have said the greatest bang for the buck for fixing braking related steering shakes is rotors, then comes tie rods and end links.
Old Sep 24, 2007 | 08:55 PM
Drug Money
wow I'm sorry.
You want to make sure you don't BREAK anything while you're BRAKING
that bothers me a lot.
Old Sep 24, 2007 | 09:03 PM
CoolMax's Avatar
is invisible
check out the GD forum too
http://forums.maxima.org/forumdispla...aysprune=&f=17
Old Sep 24, 2007 | 09:25 PM
jasonmax's Avatar
66k
I looked at the Rotors, they're pretty new..
Old Sep 24, 2007 | 09:30 PM
jasonmax's Avatar
Originally Posted by MaxBoost925
wow I'm sorry.
sorry, man...my english is poor..
Old Sep 24, 2007 | 09:34 PM
SoonerFan's Avatar
Cletus
do people only read their own posts
again, on our cars, the rotors arent actually warped. they SEEM warped because of pad material transfer. "turning" them removes the material. if you get better pads, you wont have the problem again.
Old Sep 24, 2007 | 09:44 PM
jasonmax's Avatar
Will it cause the problem using two kinds of pads in front wheels?
Old Sep 24, 2007 | 09:46 PM
Drug Money
that's not cool. that's like using different grades of oil in your tranny.
Old Sep 24, 2007 | 09:57 PM
jasonmax's Avatar
lol...not me. It's just like that when I got the car...I think I will change it later and see if any changes..
Old Sep 24, 2007 | 10:02 PM
SoonerFan's Avatar
Cletus
at the same time?
if you catch the problem early enough, the material transfer isnt that bad and a turn and pad swap should fix the problem.
when i changed my pads, the material build up had gotten so bad that the rotors actually wore unevenly so i had to change the rotors too
look at the outside of the rotor and how the wearline is diffirent
Old Sep 24, 2007 | 10:08 PM
jasonmax's Avatar
at the same time?
yep, at the same time...
Old Sep 24, 2007 | 10:11 PM
SoonerFan's Avatar
Cletus
different pads will wear differently and cause the problem you are having. what lazy person before you used different pads??
Old Sep 24, 2007 | 10:19 PM
jasonmax's Avatar
I don't know..I'm gonna take my car to the Nissan dealer check everything...
Any suggestions?
Old Sep 24, 2007 | 10:23 PM
SoonerFan's Avatar
Cletus
Any suggestions?
dont go to Nissan...you just need to change both front pads. you can do it yourself or have a brake place do it for cheaper.
with different pads you are getting different pad material transfer and different pad wear. pads whould be the same brand and installed at the same time
Old Sep 24, 2007 | 10:28 PM
jasonmax's Avatar
ok...thanks...I think I should do it ASAP.
Old Sep 24, 2007 | 10:31 PM
jasonmax's Avatar
here is a picture of my rotor. I think it's ok. Just pads problem..
Old Sep 24, 2007 | 10:39 PM
SoonerFan's Avatar
Cletus
they look OK but i cant tell. i would still let a brake place check them out.
Old Sep 24, 2007 | 10:43 PM
jasonmax's Avatar
I'm new in my place...So where should I go? I live in Omaha..
Old Sep 24, 2007 | 10:44 PM
SoonerFan's Avatar
Cletus
any car place can do it. a place that does oil changes.
ask in your regional forum.
Old Sep 24, 2007 | 11:03 PM
Birchrj's Avatar
Warped rotors
Your rotors don't get "material transfer." They warp because they get hot. The better the material the rotors are made from, the less likely they are to warp. It also depends on how hard your on and off of your brakes and if they have time to cool down between extreme driving times. If you have the money to buy good rotors, go for it. If not, see if you have enough rotor left to turn and then save up for good rotors later on.
The reason the rotors that you were shown have one side thinner than the other isn't "material transfer." It is because the caliper piston is on the inside of the rotor, and the piston doesn't always release all the way. As a result, the inner brake pad tends to retain more pressure than the pad on the outside of the rotor, thus wearing down the inside of the rotor faster than the outside, not because of "material transfer." Also, look for heat checking on your rotors, small little cracks running on the surface of the rotor. This indicates that the rotors have been extrememly hot.
The only "material transfer" that you get on your brakes is when you glaze the rotor surface, which is when the resin from the brake pads gets so hot that it does transfer to the rotor. This doesnt warp the rotor, it just makes your brakes squeal, and decreases the effectiveness of your braking system. This glaze can be removed by burninshing your brakes, but that is for a different discussion.
Old Sep 24, 2007 | 11:09 PM
SoonerFan's Avatar
Cletus
dude, its a well known and proven fact that our rotor "warp" due to material transfer from OEM pads. the rotors get hot and the inferior material transfers.
i changed my rotors to OEM replacement with Hawk pads...they have around 5K miles on them (including auto-x). there has been no warping and the rotors havent warn unevenly. that proves that the pads were the problem.
i know what im talking about.
Old Sep 25, 2007 | 12:21 AM
aznaliaz's Avatar
rotors warp when it gets hot and hits water(rapid cool down). i dink all rotors will warp.
Old Sep 25, 2007 | 12:23 AM
Drug Money
that can happen - but not a common issue in 5th gens.
OEM rotors and pads warp because of material transfer.
Old Sep 25, 2007 | 06:14 AM
ghostrider17's Avatar
You're both right - er, wrong....
As for the AGE-OLD debate:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Does anybody know the RUN-OUT VALUE for OEM rotors???
ie: what's the min. thickness on the rotor surface(s) that NIssan allows?
I've got two sets of rotors, and they've BOTH been lathed one-time each.
I'm wondering if I can get one more "slice" off of them before they're shot.
Spare me the "buy new rotors" comments -- I understand all of that. This is my choice. Rotors on my car don't last 10k, even when NEW, and with Hawk Pads.
Must be my "late-braking" stylie.....
gr
Old Sep 25, 2007 | 06:25 AM
upstatemax's Avatar
Stop typing if this is the crap you are going to put up...
The Material transfer is a well known reason for the brake pulsating on stock Maxima brakes.
Old Sep 25, 2007 | 06:32 AM
upstatemax's Avatar
gr
IMO, I don't like turning rotors ever... By the time I have the actual need to do such, they have been on the car for a few years and have seen better days. I just invest in new rotors, they are cheap enough.
If you have turned them once, I would not waste your time doing it again. IF you brake that hard, you will kill them in no time since they will be so much thinner than brand new rotors.
