Just got my new valve covers (pic)
Old Feb 25, 2011 | 12:27 PM
  #121
kvk2003max's Avatar
Originally Posted by RR5
The www.nissanparts.cc site comes back page not found for me and downforeveryoneorjustme.com says the site is down.
I had a look on http://www.courtesyparts.com/maxima-...2670_2674.html
There are no valve covers (rocker cover assembly) which match the part numbers:
13264-7Y000 Cover
13264-7Y010 Cover
13270-EA20A Gasket
13270-EA21A Gasket
But the first part numbers do match, the 13264. I want to be certain of ordering the right part. I'll have a chat with Dave B and see what prices I get.
can someone identify the part # for the rear cover and gasket. I would just like to change the rear one which has the issue. TIA.
Old Feb 25, 2011 | 01:24 PM
  #122
RR5's Avatar
RR5
The rear valve cover will have the PCV valve on it, where the front valve cover will not. Also the front valve cover will have the oil cap cutout.
-Edit, you're probably better replacing both valve covers and gaskets. This only helps later on down the road which is why I went crazy and got both valve covers myself.
-Edit 2, Have a look on http://www.courtesyparts.com/maxima-...2670_2674.html
13264 is the rear valve cover and 13264+A is the front valve cover.
Old Mar 31, 2011 | 07:22 AM
  #123
Prophecy99's Avatar
i am trying to understand a little bit better with oil in the spark plug tube seals
If there is any oil in these areas is it no doubt a valve cover leak and only that?
Or is it only when certain tubes like #5 have oil that it is a valve cover leak? (im guessing that just lets you know the location of the leak)
Thanks.
unlike others I am paying a friend to do this work and I need to be informed on this so I dont just request to change the Valve covers for nothing.
Old Mar 31, 2011 | 09:26 AM
  #124
nismopc's Avatar
Thanks.
You can not just purchase the spark plug seals seperately. They are part of the valve cover, so it doesn't matter either way. If you have oil in the opening, replacing valve cover is only route.
Old Mar 31, 2011 | 09:49 AM
  #125
Prophecy99's Avatar
Thanks nismopc. .. the question was more or less... was there anything else that could cause oil to be in those areas.
Old Apr 1, 2011 | 03:56 AM
  #126
6spdmax's Avatar
I just picked up my new rear VC yesterday, along with a new VC gasket. I pulled the front coils a couple days ago, and all those wells were clean as a whistle. I also spot checked one of the plugs, and it is really worn down after 119K miles. Replacing them with NGK Iridium IX plugs. In addition to the plenum gasket, I also picked up the gasket for between the plenum and elbow, and the one for between the TB and elbow. This is just in case I need them. I can return those 2 if not needed. Gonna do the job tomorrow at a buddy's house. He recently changed plugs on an Altima 3.5.
Old Apr 1, 2011 | 06:23 AM
  #127
SurraTT's Avatar
HR Swap Pioneer
^^ Nice,
usually just the rear is the one that's leaking, but i went ahead and done both.
Old Jun 8, 2011 | 12:43 PM
  #128
Nathan's Avatar
Is it okay to use a 2002 gasket when installing a 2004 rear valve cover?
Old Jun 9, 2011 | 05:58 AM
  #129
matt06's Avatar
try reading FFS
Old Jun 11, 2011 | 01:02 PM
  #130
Nathan's Avatar
Originally Posted by matt06
try reading FFS
Wow, that was a lot of help, thanks. Care to tell me what "FFS" means?
Old Jul 15, 2011 | 08:02 PM
  #131
REDL1NE's Avatar
Sorry to bump this older thread, but great info. Will be doing this with my plug change real soon.
Thanks!
Old Jul 17, 2011 | 11:01 AM
  #132
RR5's Avatar
RR5
2004 valve covers need the 2004 gaskets. Call DaveB.
Old Nov 12, 2011 | 01:37 PM
  #133
03VQMAX's Avatar
I know, bumping an old thread, but is it right for one valve cover to be bigger than another? Someone let me know before I go ham.
Old Nov 12, 2011 | 05:44 PM
  #134
spock's Avatar
Don't really know what you mean. Just order & install the 6th gen valve cover & gasket and...you're covered.
Old Nov 12, 2011 | 05:56 PM
  #135
03VQMAX's Avatar
I mean what I said, was your covers one bigger than another?
Old Nov 12, 2011 | 06:09 PM
  #136
spock's Avatar
Didn't notice, to be honest. I just installed the 6th gen cover and gasket. It fit without any difficulty.
Old Nov 12, 2011 | 06:50 PM
  #137
03VQMAX's Avatar
Oh, you only did the rear?
Old Nov 12, 2011 | 06:51 PM
  #138
02slead's Avatar
good news about the covers I have a leaking one in the rear and it was expensive but now I will go get it thank you
Old Nov 12, 2011 | 07:59 PM
  #139
spock's Avatar
Yes. Right bank or firewall side. The left or rad side isn't leaking.
Old Nov 12, 2011 | 08:54 PM
  #140
SurraTT's Avatar
HR Swap Pioneer
Do you mean comparing the front and rear to each other? or 5.5 gen and 6th gen?
The front cover is a little wider
5.5 and 6th gen VC are the same.
here u can see the front one is a little "wider"
Old Nov 12, 2011 | 09:11 PM
  #141
03VQMAX's Avatar
Yea, that's it, so it is a little wider, just making to make sure because the boxes also came in different sizes.
Old Nov 25, 2011 | 08:05 AM
  #142
MONTE 01&97 SE's Avatar
When you guys replaced the front valve cover gasket does it require a sealant?
Old Nov 25, 2011 | 08:28 AM
  #143
nelledge's Avatar
"I'm just sayin'..."
Yes. Apply it at the front corners near the camshaft bracket. See EM-50.
Old Nov 25, 2011 | 08:47 AM
  #144
Thanks man
Old Nov 25, 2011 | 11:21 AM
  #145
RR5's Avatar
RR5
Both valve covers require the liquid gasket. Pickup some 10 minute stuff from Autozone if you hate waiting.
Old Nov 25, 2011 | 01:09 PM
  #146
So when replacing the front AKA as left only, do you guys recommend replacing just the gasket itself or going with the 04+ valve cover and gasket?
Old Nov 25, 2011 | 01:43 PM
  #147
nelledge's Avatar
04 Valve Cover and gasket. Why are you only replacing the 'front'?
Old Nov 26, 2011 | 10:09 AM
  #148
03VQMAX's Avatar
I just did my rear valve cover, wasn't that bad since I already knew how to take the Mani off, letting the car sit over night so the sealer can dry, although I do think 86 inch lbs is kind of soft for the bolts, but that's what the manual says.
Old Nov 26, 2011 | 10:17 AM
  #149
Back one not leaking yet, when it does I will have to make real time to tackle that.
Old Nov 26, 2011 | 10:39 AM
  #150
03VQMAX's Avatar
If and when you do/did your spark plugs, you should change the rear cover/gasket. I was told to do so, and I didn't listen and now I had to take of the intake manifold again and do it, was only a year ago I did the sparks.
Old Dec 5, 2011 | 03:47 AM
  #151
kingrukus's Avatar
no more maxima...
Does this solve the VQ35 oil burning issues? Sorry about this shot in the dark question, I really have no clue.
Old Dec 5, 2011 | 05:34 AM
  #152
MrEous's Avatar
^ Jeff™
It might...it might not. It helped on mine because I could see where the oil was leaking out onto the rear header...but I was only going through a quart every 5k, if that.
(for oil LOSS, as SurraTT explains below)
Old Dec 5, 2011 | 07:31 AM
  #153
SurraTT's Avatar
HR Swap Pioneer
It wont help oil burning, but it might help oil loss. As the oil will stay in the motor rather then leaking out.
Old Dec 5, 2011 | 08:26 AM
  #154
ranmas2004's Avatar
Is the oil consuming issue just on the 02-03 Maxima VQ35DEs or is that ALL VQ35DE and HR engines?? And has there been any reports of oil burning on the new VQ37VHR engines? Those engines are beasty!!!
Old Dec 5, 2011 | 10:12 AM
  #155
SurraTT's Avatar
HR Swap Pioneer
Its complicated, but 02 03 FWD def have it. 04-08 i think its more hit and miss. 09+ seem to be just fine
RWD- DE's mixed up some bad some none
Rev ups- i think are the worst
HR's and newer seem to be fine
Old Dec 5, 2011 | 12:01 PM
  #156
RR5's Avatar
RR5
If you do some searching, you can find the thread where someone tore down an oil burning VQ. The final analysis was the piston rings allowed oil blow by which is burned during combustion. Not sure if dropping in better quality piston rings would totally solve the oil burning problem. I for one would love to compare the piston rings from the VQ with the HR engine series.
-I was bored. Link is http://forums.maxima.org/5th-generat...ront-bank.html
Old Dec 5, 2011 | 12:26 PM
  #157
ranmas2004's Avatar
Man, I'll just live with the quart of oil I have to put in every once in a while. Rebuilding an engine is expensive!
Old Dec 6, 2011 | 01:28 AM
  #158
RR5's Avatar
RR5
You could cut the costs down by farming out the one thing you want done. "I only need new piston rings, nothing more." Then see which places offer the best quotes. I would think the most difficult part of that job is physically hoisting the engine out of the vehicle.
After that, given the forums you can walk your way through the piston ring replacement on your own!
Old Dec 6, 2011 | 06:44 AM
  #159
ranmas2004's Avatar
Hey Surratt what kind of torque wrench you use to torque the VCs down? In the FSM it says its in-lbs or something like that not the standard ft-lbs that you see in the stores. I believe it said 80 in-lbs.....can't remember.
Old Dec 6, 2011 | 06:47 AM
  #160
SurraTT's Avatar
HR Swap Pioneer
You use a inch lb torque wrench, these are usually 3/8 drive instead of the bigger 1/2 drive ft tq wrenches.
Its good to have both of these torque wrenches!
