Car dies upon startup
Old Oct 2, 2007 | 11:39 AM
Soon2bMD's Avatar
When I start my car (02 GLE) it immediately dies if I don't tap the gas pedal. I don't really have to rev it, just give it a little bit of gas and then its good to go and it will idle. I had a SES light come up and got that fixed; I had a crack in the gas cap. It did this before the fix and now after the fix. Any suggestions as to what it could be?
Old Oct 2, 2007 | 01:14 PM
huffdaddy2008's Avatar
Mine just recently stopped doing this. GL
http://forums.maxima.org/showthread....27#post5979727
Old Oct 2, 2007 | 07:36 PM
Soon2bMD's Avatar
Thanks. I called the dealer and they said it'd be about $80 just to look at it to identify the problem. I was hoping to get some insight from here first, though.
Old Oct 2, 2007 | 09:16 PM
Keep us updated on what they tell u. The dealership here said i had an MAF "anomalae" I think its about to go.
Old Oct 2, 2007 | 09:20 PM
SilverGLE's Avatar
I'm watching you, boy...
Does it idle roughly then die? I had a similar issue, which turned out to be a combination of the MAF and coils...
Old Oct 2, 2007 | 09:23 PM
Soon2bMD's Avatar
Nope, it starts up just like normal and then the engine just dies. Very similar to just turning the key to off, smooth shutoff and no rough jerks or anything. When I do rev it a little to keep it from dying it is a smooth idle and it drives perfect too. I think if I had a rough idle I'd be more worried; however, this still concerns me.
Old Oct 2, 2007 | 11:52 PM
gxe2se's Avatar
Mine had the same issue. When the car was warm (normal temp) it would die on me. Ended up being the MAF. It was replace and it was good to go.
Good luck
-Anthony
Old Oct 3, 2007 | 12:48 AM
getbigtony's Avatar
clean your TB
maybe IAC is getting stuck
Old Oct 3, 2007 | 01:36 AM
MaxBoost925's Avatar
Drug Money
It's your coilpacks or your MAF. swap those out, it's maintenance.
Old Oct 3, 2007 | 06:14 AM
dannypmax's Avatar
could just be your throttle body, it has happened to me two times in two years (both at the end of the summer). Had my throttle body cleaned and problem went away.
Old Oct 3, 2007 | 11:26 AM
Drug Money
Highly unlikely.
Old Oct 3, 2007 | 11:30 AM
Soon2bMD's Avatar
Is the mass air flow sensor covered under the emmisions warranty? I called the dealership and they said the only thing that the emmisions warranty covers is the catalytic converter and thats it. I immediately thought BS but I thought I'd check first.
Old Oct 3, 2007 | 09:27 PM
Soon2bMD's Avatar
Anybody?
Old Oct 3, 2007 | 09:48 PM
gxe2se's Avatar
about the MAF? I don't think it covered, unless you got an extended warranty or something.
I remember getting mine replaced under the dealership when I still had my warranty active.
Its about $100 for the part + labor.
Old Oct 3, 2007 | 11:17 PM
I thought it was a lot more than that, like $400, and less reliable. Thats why people buy the 00/01 MAF sensor because its cheaper and supposed to be more durable. I dont wanna search for the thread i read that from. Im supposed to be studying...
Old Oct 4, 2007 | 07:42 AM
Nathan's Avatar
Soon2bMD, I've had the exact same problem with my 2k2 SE for a while now. About 2 years ago I had my auto tranny replaced and at the same time the dealership gave me a new MAF under warranty. They also reset my ECU. After this was done, the dying at start-up went away, but a few months later it started acting up again.
So I think the guys are right, in that it's either related to the coils or a dirty throttle body. Mind you, I haven't cleaned my TB since I bought the car new.
As for the cost of the MAF, '02-03 MAF's are much more costlier than 00-01 MAF's, which is why people buy 00-01's. Only thing is that the '00-01 MAF's will throw a CEL.
Old Oct 4, 2007 | 09:55 AM
dannypmax's Avatar
I would think that a bad coil or a bad MAF would throw a code (actually I know since my 2000 max has had all the coils and the MAF replaced after I got codes for them) while a dirty throttle body will not throw a code in my experience. A lot cheaper fix to have your throttle body cleaned than to start throwing coils and and a MAF at it, just my $.02.
Old Oct 4, 2007 | 02:48 PM
Soon2bMD's Avatar
Interesting stuff, thanks for the replies! I was searching around about the TB stuff and I read that soonerfan (think it was him) was advising against cleaning the TB because it was quite easy to mess something up?
Old Oct 4, 2007 | 07:45 PM
Ya, general consensus is dont clean it.
Old Oct 14, 2007 | 02:57 AM
maxfive-O's Avatar
Did you change your oil lately? maybe to a lighter 5-30 wt? I had the same problem, turns out that the oil pressure switch didn't read any pressure during start up. Changed back to 10-30 mobil and no problems.
Good luck
Old Oct 14, 2007 | 04:32 PM
NisTech's Avatar
you need to perform an idle air volume learn and might as well do a throttle chamber service at the same time. 1 hr labour
Old Oct 14, 2007 | 05:11 PM
jasonmax's Avatar
Originally Posted by getbigtony
clean your TB
Agree, my father's car does this when TB gets dirty.
Old Oct 14, 2007 | 06:59 PM
Pearltt's Avatar
I had the same problem....Cleaned the throttle body.... worked like a charm...car even has a better and smoother acceleration
Old Oct 18, 2007 | 01:36 PM
Dayton100's Avatar
Yeah I still have this problem at startup (exactly the same problem) I replaced new batteries, new alternator (twice), new starter motor, 2000-2001 MAF, I guess I need to clean my TB.
Old Oct 19, 2007 | 07:21 AM
getbigtony's Avatar
damn u sure wasted a lot of money
one more thing people overlook is HVAC purge valve
if it's a bad valve, it may cause you to run too rich or too lean, so much that it has hard time to start
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
