None of the FAQs seem to be working and I have a question
Old Oct 8, 2007 | 03:34 PM
Whitebread's Avatar
I looked through the FAQs because I need to find out what code or codes is causing my CEL light to come one. There are a few links in the FAQs about my problem , but they all lead to useless threads having nothing to do with my problem. Some even link to threads outside this subforum. I also tried searching and couldn't figure out how to check the CEL codes whatsoever.
So, does anyone know how to check the CEL codes on a 2k2 Maxima?
Thanks.
Old Oct 8, 2007 | 03:40 PM
NmexMAX's Avatar
dot dot dot ...
To be honest, you could probably save some time and head to AutoZone and have them read the codes.
Trying to get them on your own (w/o an OBDII reader) it's a little tedious and the codes are very difficult to decipher.
Old Oct 8, 2007 | 03:46 PM
Whitebread's Avatar
Well then I have two questions for you.
1: Is there any OBDII reader software for a laptop?
2: Do you know how to read the codes without the OBDII reader? I'm curious as to how it would be done.
Old Oct 8, 2007 | 04:10 PM
NmexMAX's Avatar
dot dot dot ...
Auterra/UpRev/AutoEnginuity/HarrisonR&D to name a few. Not to mention those cheaper AutoZone units that do not require a laptop.
How to Set Diagnostic Test Mode II (Self-diagnostic Results)
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following procedure quickly five times within 5 seconds.
1) Fully depress the accelerator pedal.
2) Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the MIL starts
blinking.
4. Fully release the accelerator pedal.
ECM has entered to Diagnostic Test Mode II (Self-diagnostic results).
Read what the code means here.
http://forums.maxima.org/showpost.ph...6&postcount=65
Old Oct 8, 2007 | 04:11 PM
SoonerFan's Avatar
Cletus
FYI, codes are not car specific...all OBDII cars have the same codes
1. go to autozone
2. get code
3. google code
Old Oct 8, 2007 | 04:18 PM
NmexMAX's Avatar
dot dot dot ...
But the way Nissan makes them blink. ,.... My blinker fluid must need to be changed because the blinks never make sense.
Old Oct 8, 2007 | 04:39 PM
Whitebread's Avatar
Thanks.
The CEL light flashed P0011 which corresponds to IVT control. I'll check your link
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
