Addco RSB, did this happen to you?
Old Oct 20, 2001 | 08:50 AM
THEKNITE's Avatar
I was unable to position the bushings and u bolts around the axle close to the bends, since it was hitting the suspension arm on the passanger side everytime i went over a bump. I fixed the problem moving the bushing, and tighten it few inches away from the bend towards the middle. i was wondering if it happened to anyone?
thnx
Old Oct 20, 2001 | 09:22 AM
Sly's Avatar
Sly
Yup, that's the quick simple fix. Or you can do what I did and trim the brackets so they don't stick out too much.
Old Oct 20, 2001 | 10:10 AM
MaDxKiLLa's Avatar
can u explain how to fix the problem in more simple terms.....? Whenever I go over a bump I hear a clunking sound!
Old Oct 20, 2001 | 10:42 AM
Sly's Avatar
Sly
1) Loosen the brackets on the mid section of the RSB.
2) Slide them inboard from the bends about 5 inches each.
3) Retighten the nuts to spec.
4) While you're down there, double check the other brackets are properly seated and retighten those as necessary.
5) Inspect all parts (RSB and suspension) to see if there are any unusual scrapes, scratches or rub marks.
6) Drive happy knowing you saved a few bucks over the Stillen bar.
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
