Re: air filter replacement
Old Oct 15, 2007 | 03:10 PM
Peanuthead's Avatar
I looked in the FSM and it says that the air filter doesn't need to be replaced. I tried to take it out but I only see 2 snap tabs at the top and the "moving" door on top of the filter box assembly. Am I missing something when I am trying to take it out.
Old Oct 15, 2007 | 03:52 PM
BigFly_2K2SE's Avatar
There is no way that the FSM says that the air filter doesn't need to be replaced. It is a regular maintenance item.
Undo the two snap tabs, pull the filter housing towards you and then up through the hole. The filter is inside the housing. I am not sure I understand the problem.
Old Oct 15, 2007 | 03:53 PM
Iceman420's Avatar
(insert witty one liner)
Once you "unsnap" it, a plastic housing just slides up an out. The air filter is in that plastic housing. Should be really easy, I just put a K&N in a couple of days ago with no trouble at all. It may be differant for cars older than 2003, I have no idea.
Old Oct 15, 2007 | 03:54 PM
Peanuthead's Avatar
I perhaps read something wrong then. I undid the two tabs and the filter doesn't seem to want to come out. I wonder if it is the right filter for the unit. There is nothing to grab other then the sides. I know how to change an air filter but this one is giving me grief.
Iceman420's Avatar
Looks like you beat me to it.
Old Oct 15, 2007 | 04:12 PM
Peanuthead's Avatar
Wow! I just figured it out. I needed to step away and come back to it I guess. I just looked at the FSM on page 17 in the MA.pdf. Noe sure what a "viscous" paper type filter is other then the stock one.
95Maxi
Aug 29, 2015 09:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
