window switch reset
Old Oct 13, 2007 | 07:21 PM
knight_yyz's Avatar
Toolie
window switch reset
Hey guys, I can roll the front passenger window down with my drivers side switch. But I can't roll it back up. I can hear a clicking noise on the passenger side when I attempt it, which makes me believe the window wants to go up but nothing happens. Will the reset procedure work for this or do I need a new window switch cluster?
Old Oct 13, 2007 | 07:33 PM
Gemini67's Avatar
I have the same problem on my 03 GLE. I found that wiggling the switch or pressing it to one side while pulling up on it will bring the window up. I suspect the master switch on the driver's side needs to be replaced but I'm too cheap right now.
Old Oct 13, 2007 | 07:46 PM
Stardust's Avatar
F---ing Kangaroos
will it roll up using the passenger side switch?
Old Oct 13, 2007 | 07:59 PM
Gemini67's Avatar
@Stardust "will it roll up using the passenger side switch?"
If it's anything like my car then the answer should be yes, I have no problems rolling it up from the passenger side switch.
Shogunsc4's Avatar
I'm having similar problems with the window control for a while. Only mine would roll up and automatically comes down 1/4. It only happens to the front passenger side. I have reset the passenger door like 4 times the past year and it will re-occur after a month or two. Weird.
Old Oct 13, 2007 | 08:01 PM
Gemini67's Avatar
Yah... you have the reset issue the OP has the master switch issue
Old Oct 13, 2007 | 10:55 PM
knight_yyz's Avatar
Toolie
same here, I can roll it up with the passenger switch.
Old Oct 14, 2007 | 08:48 AM
NY'er's Avatar
Hi All,
1st post~ I'm having the opposite problem on my 2001... the driver's side switch will roll the passenger side window up, but the passenger side switch will not. Forgive the noob-ness, but what do you mean about resetting the switch, and would that apply to my issue?
Thanks!!!
NY'er
Old Oct 15, 2007 | 12:36 AM
wsrivers's Avatar
Pardon my noobiness. I'm havining the same problem but with my rear passenger side window and the passenger window rolls 1/4 of the way down on an auto close. How do I reset the window switch too.
Old Oct 15, 2007 | 09:23 AM
jasonmax's Avatar
I think you guys should dry your switches, maybe they are in a bad connection.
Need to sand the pins maybe.
Old Oct 15, 2007 | 04:52 PM
Dayton100's Avatar
I had a problem with my driver side window not rolling back up. (The window was already all the way down)....It happened to be the master switch (~$120, plug & play install). Everything works perfectly.
The passenger side switch has a problem rolling the window down, but it works perfectly going up. It also works great from the driver's side master switch controlling the passenger side window, up or down.
I just tell whoever gets in my car to push the switch down couple times in a row.
Old Oct 15, 2007 | 04:56 PM
Dayton100's Avatar
Sorry to get out of hand but...
Another thing is that my windows used to roll up kind of slow....
This would happen if I had my stock stereo playing @ loud volume.
After changing the alternator, it helped a little bit but I can deal with it.
Old Oct 15, 2007 | 04:57 PM
Dayton100's Avatar
I think you need to replace the master switch (about $110)
gavin68
Sep 18, 2021 12:36 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
