MAF, O2 sensors replaced but car still sluggish..
Old Oct 20, 2007 | 09:32 AM
big h's Avatar
So I had two codes in the last 3 months...one to replace the MAF and the other to replace the O2 Sensors at the catalytic coverter...all is done and no codes as of yet. However, the car seems to have rough starts which lasts around 40 seconds and then its smooth idle. At the 3000-4000rpm range, car is sluggish, no 'pep' at all. Sounds like the motor is hindered when RPM is in that range or its in safety mode...does it take awhile for the ECU to learn the air/ fuel ration again or what?
Old Oct 20, 2007 | 12:59 PM
Matt_01SE_20th's Avatar
did you have the ECU reprogrammed? That will cause it not to know what is going on with the air/fuel and run kinda funky. It will take a little while for the computer to learn the exact readings. You may want to check your VIAS system, coule improve performance, what year is it so we all know.
Old Oct 20, 2007 | 01:44 PM
aksansai's Avatar
01 Maxima SE, 5-spd
I had just posted about my MAF replacement experience today using a hint from another org member to run your car without the MAF connector attached (throws a 0101 code, I think for MAF malfunction, but easily reset) for about 30 seconds which causes the ECM to dump its old air/fuel mixture table and allows you to begin the rebuild. I ran mine for about a minute with it disconnected, shut it off. Reconnected the MAF, and then restarted and let it run for about five minutes. I took off for a drive and it feels like a new car again.
Old Oct 20, 2007 | 04:19 PM
big h's Avatar
car is a 2001, and no I havent had the ECU reset...can it be done using the tool that checks the code..i think its a scanner of somesort? For now I'll what Akansai recommends...but when the 0101 code is set off, do I need the scanner to reset? or will it reset itself?
thx for the help so far...i appreciate it.
Old Oct 20, 2007 | 04:23 PM
IHAVEA2KMAXIMA's Avatar
I just unplug the battery to reset
Old Oct 20, 2007 | 04:54 PM
big h's Avatar
so I tried the battery disconnect and it didnt work, I'll try the MAF removal tomorrow.
Old Oct 20, 2007 | 05:02 PM
paulpearl's Avatar
I replaced my maf today with fellow org member Jason00maxse and I am also leaving my negative terminal off tonite and will see how my car reacts tomorrow....Hey bigh let everyone know what happens after you try aksansai method..I am curious if I need to do this also..I don't want to give the stealership 100 for a simple reflash but it might come down to that...Thanks
Old Oct 20, 2007 | 05:34 PM
nlmaxima's Avatar
If your MAF sensor was defective and you continued to use your car it is possible you ruined your CAT. Your MAF may have been telling your ECM to dump as much fuel as possible and it may have been so much that it didn't get burned therefore raw gas would have gone out your exhaust and may have destroyed your CAT. Now the CAT may be partially blocked causing a restriction in the exhaust which is causing your problem. If you have the stock Y-pipe it is possibly your pre-CATS in the y-pipe. This would also explain an inefficient O2 code.
Old Oct 20, 2007 | 07:30 PM
For my car to reset, I usually unplug the battery for like 4hrs minimum.
Hows ur gas mileage anyway as in how many miles u can squeeze out from one tank.
Old Oct 21, 2007 | 07:51 PM
aksansai's Avatar
01 Maxima SE, 5-spd
Quickest, painless way to reset your code is to get your local auto parts store to do it for you. You can also check to see if there are more SES codes looming (active and pending) to get a better diagnosis.
Old Oct 21, 2007 | 08:07 PM
AceofSpds's Avatar
wat
they are talking about resetting the ecu so it "learns" the new maf, not dumping the codes.
Old Oct 22, 2007 | 05:15 AM
big h's Avatar
Did not gat a chance yet to try the MAF removal as of yet, but SES is back on...
Old Oct 22, 2007 | 10:22 AM
MaxBoost925's Avatar
Drug Money
Pull any codes out and find out what they are.
Old Oct 22, 2007 | 04:03 PM
Child_uv_KoRn's Avatar
Bad *** Newb
yeah, don't let that happen or you'll blow your engine (speaks from experience with clogged cat haha).
Old Oct 23, 2007 | 08:32 AM
NmexMAX's Avatar
dot dot dot ...
Try this on for size:
http://forums.maxima.org/showpost.ph...2&postcount=45
Old Oct 23, 2007 | 05:05 PM
big h's Avatar
pulled a P0100 - replace MAF...damn this geting stupid....i already replaced and its bad/defective...fawk!
Old Oct 24, 2007 | 10:25 AM
tonyw's Avatar
Did you have your ECU software version checked?
Take a look at http://forums.maxima.org/showthread.php?t=538422
Old Oct 26, 2007 | 02:31 PM
big h's Avatar
replaced the maf again and the car is running super...taking the car in to get the ecu update next week...oh and I ordered up a code scannner, its called Jem J1000 and its $75 + shipping....seems like a very good investment now that the car is starting to require alot more maintenance...thx for the help guys
Old Jan 18, 2008 | 08:21 PM
mikemaximus's Avatar
i have an 01 se with 90 some thousand miles and had the ses code you all speak of. took it to my local mechanic who seems trustworthy although he seems to be more of a domestic car guy. he replaced the 02 sensor and the light went off for about a week. the light comes and goes and im getting bad mileage (about 20, i used to get almost 30) i had a stalling problem last fall just before i got the 02 replaced. it fixed that problem, but the mechanic said the new code was for another 02 sensor. i've read about a million posts on here about new mafs and o2's and unhooking the maf and reprogramming the ecu, but most of them pick up after the owner had a ton of stuff replaced. im trying to avoid replacing too much. where do i start? straight to a new maf? if so, what tools are needed, and what about unhooking it and.or ecu reprogramming? or should i keep replacing 02's? basically i have seen all the suggestions, but im not sure of the order i should start with. sorry for rambling. any help is appreciated. thanks
mrc00l88
Jan 25, 2024 01:14 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
