Oxygen Sensors - Should I replace them?
Old Oct 31, 2007 | 06:47 PM
kroe's Avatar
I have an 01 20th anniversary maxima and am getting a sporatic P0171 code (lean bank 1). It comes on for a few days, goes off for a few... seems to be on more than off lately.
From what I understand o2 sensors are only good for about 100k, I have 130k on the car. Should I replace the o2 sensors and hope the code goes away? Would replacing them be beneficial anyway to improve fuel economy? If so should I replace just the front two, or all four?
Old Oct 31, 2007 | 07:44 PM
tonyw's Avatar
Take a look at this http://forums.maxima.org/showthread.php?t=538422. I just went through that same thing with my 20th Anniv and it was the Air Flow Meter.
An experienced Nissan Tech said the 2000-2001 Maximas have weak air flow meters and as they fail (or get dirty) they post the P0171 code (makes no sense to me either). Try cleaning it first and then if you still get the codes replace it. It's about $80 from Rosenthal Nissan-Mazda www.mazda-parts-dealer.com.
Once you replace it, you'll need to have your ECM software version checked. There is a Nissan TSB about that process. If you do the replacement, take the car to the dealer to have the software checked. If you pay them to do the whole job, they should check it as part of the AFM replacement.
Old Oct 31, 2007 | 07:50 PM
NmexMAX's Avatar
dot dot dot ...
It makes sense because the MAF is responsible for AFR during WOT operation, and if it's lean, then the code pops up, saying it's lean, which leads to the MAF.
Old Oct 31, 2007 | 08:51 PM
tonyw's Avatar
The MAF is responsible for the AFM during all operations, not just WOT. Cars don't run at WOT that often so it makes sense that the MAF works all the time...
Old Oct 31, 2007 | 08:56 PM
crazy97's Avatar
Soon after I bought my 97 with 157K, all 3 GD o2 sensors went dead one after another followed by the KS. I vote to replace them all.
Old Oct 31, 2007 | 09:00 PM
NmexMAX's Avatar
dot dot dot ...
But that code is not O2 sensor related. The past has shown it to be MAF related.
Old Oct 31, 2007 | 09:01 PM
made in china's Avatar
I'd replace them all. I lost one o2 sensor recently (0v out, dead). It started as an intermittent, my car would occasionally run rich, idle slightly rough and my MPG's have dropped by 6-8MPG. Now that o2 is constantly dead. How about your MPG?
Old Oct 31, 2007 | 09:05 PM
crazy97's Avatar
I remember getting a lean code just before the o2s went out.
NmexMAX's Avatar
dot dot dot ...
I only have 2 of my 4 O2 sensor on my car and I don't run rich nor have sputtering problems.
I'm still voting MAF.
Old Oct 31, 2007 | 09:53 PM
I only have 1 of the 4 working. I had no downstream O2's, and my old 1997 O2 I was using as one of my upstreams failed. So as far as the ECU is concerned, one bank is lean. Throws my car outta whack.
But I'd say the MAF is a likely prob too. I'd still say O2's first.
Old Nov 1, 2007 | 05:24 AM
MichMaxFan's Avatar
How do you guys run w/ out all the o2 sensors working? SES stays on all the time?? How does the system let you do that w/ out the lights on the dash going wild?
Old Nov 1, 2007 | 05:36 AM
MichMaxFan's Avatar
[QUOTE=tonyw;6041801]Take a look at this http://forums.maxima.org/showthread.php?t=538422.
QUOTE]
Are you on drugs? It's $390 on their website today...another ripoff...Call Dave B for all the OEM parts. I'm glad I did...
BTW, their website is too much like another one, so I think their is no diff in pricing from the website you mentioned to another one out there, unless the design was just a cookie cutter thing, but I doubt it. Too many of these parts sites seem to be alike and prob under the same ownership...
Old Nov 1, 2007 | 11:35 AM
tonyw's Avatar
No drugs!! Check again...Part number is 22680-2Y001 and it's $78.93 on their site!!
You must have been smoking something and were looking at the old AFM. There is a new one available (as noted in the Nissan TSB).
Old Nov 1, 2007 | 12:38 PM
HotMaxx02's Avatar
I need my primary front o2 replaced.
Dealer Quoted $156.00
Dave B is $120-ish
But i can get a generic one off ebay for $100... as long as it the correct sensor it will work... RIGHT???
Any thoughts or experiances?
Old Nov 1, 2007 | 12:53 PM
NmexMAX's Avatar
dot dot dot ...
Dave B is $120-ish
Is this a thread jack?
Old Nov 1, 2007 | 01:28 PM
HotMaxx02's Avatar
Somthing like that...
BUT it is on the topic.
I just wanted to know if i spend the $100 to buy generic will i be spending and Additional $156 in 6 mos to a yr to buy a Nissan OE o2 sensor?
Old Nov 1, 2007 | 03:36 PM
tonyw's Avatar
Go to www.ngk.com. They have OEM type O2 sensors at good prices.
Old Nov 1, 2007 | 03:53 PM
IHAVEA2KMAXIMA's Avatar
just pay like $20 more and get oem from daveB with 3day UPS.
Old Nov 1, 2007 | 04:35 PM
kroe's Avatar
My gas mileage is consistently 23 mpg with almost completely highway driving. Is that good or bad?
I ordered two 3 wire bosch universal o2 sensors from ebay - $25 each. For that price I might as well replace them. If that doesn't fix it I am going to do the MAF, though paying the dealer for a software upgrade doesn't sound fun.
Old Nov 2, 2007 | 10:33 AM
HotMaxx02's Avatar
Dam good price... just bought one...
$106.67 shipped to my door.
Old Nov 2, 2007 | 05:54 PM
blkAEmax82's Avatar
Glory Glory Man United
Just wondering (dont mean to jack the thread) if you got a link for the TSB . I got the same codes and i got 2 front 02 sensors i need to put in . but looks like ill be buying a MAF as well ..
mrc00l88
Jan 25, 2024 01:14 PM
Rage Maximus
Sep 3, 2015 12:26 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
