2k2 idling too low at 200 rpm when stopped
Old Nov 5, 2007 | 05:51 PM
Mugen13's Avatar
Good thing is that the car doesnt die when stopped. It just make sitting in the cabin a little shaky.
At first I thought I had a vacuum leak when I put my head next to the engine standing from the passenger side because I can hear a "sucking" sound, but my friends maxima also has the same "sucking" noise
I remember reading about a idle re-learning procedure a long time ago, but I'm not sure if its for the 2k2. One step is to unplug a brown plug, but I dont remember the rest.
HELP!
Old Nov 5, 2007 | 07:34 PM
Whiggy's Avatar
Originally Posted by Mugen13
unplug a brown plug
LOL, I think that's for the 4th gen. Read the stickies for instructions for the 5th gen.
Old Nov 5, 2007 | 08:19 PM
CMax03's Avatar
possible vacuum leak!
HELP!
Remove the decortive cover and check those vacuum lines. If they're ok spray some carb cleaner around the intake manifold mating surfaces. Another good why to find vacuum leaks is with a hose to the ear if you don't own a automotive stethoscope!
Old Nov 6, 2007 | 08:32 PM
Mugen13's Avatar
I went to the stickies and clicked on the "Idle Air Volume Learning Procedure For 2002-2003" link... http://forums.maxima.org/showthread....38#post2411638
but I can't see it bc it gives me these reasons. Can someone post the instructions for me? Thanks!
Mugen13, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
Old Nov 6, 2007 | 08:44 PM
DrunkieTheBear's Avatar
Turbo'd Saab
http://forums.maxima.org/showpost.ph...&postcount=103
Old Nov 7, 2007 | 01:20 PM
bwinter7's Avatar
My 2k2 does this as well. I find though if I let her loose for a quick spirited run on the highway or a lot of near-redline shifts, the next time I come to a light or I idle, I am at a perfect, smooth 650 or 750. But if I don't open her up, she will idle at 200-300 and is a little shaky, but it's not that bad.
I'm thinking my injectors could be a little clogged, and the high rpms clear them out. Just like the old "Italian Tune-Up" when you had to blow the carbon out of the jets on the carb or something lol
Old Nov 8, 2007 | 05:24 PM
Mugen13's Avatar
maybe i should try red-lining my car and see what that does/feels like lol
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
bryants95max
Oct 2, 2015 12:52 PM
Maxxx10
Sep 13, 2015 03:16 PM
ballerchris510
Sep 10, 2015 09:35 PM
