StS Help 5.5 6 Speed
Old Nov 9, 2007 | 04:46 PM
Reket's Avatar
I have just purchased a Fast Shift Sts its used so no instructions but after I installed it I cant put the car in reverse it seems as if it cannot grab reverse like the shifter doesnt go back enough to grab all the way ( the shifter moved back instead of forward, i dont know if this is normal because the 4th gens move forward with a short shifter). Here are pics of the Sts any help greatly appreciated and FastShift.com no longer exists.
Old Nov 9, 2007 | 04:56 PM
SoonerFan's Avatar
Cletus
its huge...and blurry as hell
but looks like the piece used in all other STSs
Old Nov 9, 2007 | 05:08 PM
DasYears
let your car roll a little bit. sometimes the gears dont line up. just rolling a bit usually helps
Old Nov 10, 2007 | 10:23 AM
maxspeed96CT's Avatar
The original VQ...
make sure you properly hooked up the two linkage lines.
Other wise, like the other guys said, let the car roll or give the car alil gas and it may pop in to place.
It also may feel like its not in gear , but remeber you have short shifter now so reverse will feel shorter as well. So it may as well be in gear.
Old Nov 10, 2007 | 10:43 AM
Reket's Avatar
well its definetly not in gear because when i try to reverse the gear grinds
Old Nov 10, 2007 | 10:59 AM
Reket's Avatar
Ok got it, ok got it to work I was pushing the linkage back (closer to the engine there by making the shifter go back too far) when I should have pulled it out (making the shifter move forward). Thanks for all your help guys.
Old Nov 10, 2007 | 04:42 PM
Punky's Avatar
how did you like the sts? mind if i asked if i ask how the shift feels.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
