5 Speed shift points.
Old Oct 23, 2001 | 06:54 AM
SVTTODAMAX's Avatar
I have just had a new catback installed and I have noticed changes in the shift points. 1st Gear red @ 45, 2nd red @ 75,3rd red @ 105,4th not tested yet. Is this the normal redline shift points?? I don't remember them being that high is this typical for those with catback systems??
Old Oct 23, 2001 | 07:00 AM
maxse01's Avatar
Re: 5 Speed shift points.
I think your spedo must be off then. You should only be able to go 38, 67, 98, 130 and 5th i beleive is 160. I have not gotten more than 1 mph over these casue i shift just before the limiter at 6700 prm's.
Old Oct 23, 2001 | 08:33 AM
SVTTODAMAX's Avatar
Strange that it only started doing this after the install.
Old Oct 23, 2001 | 08:35 AM
ToYLeT902's Avatar
JET Speed Lab
Re: Re: 5 Speed shift points.
are you sure? 1st gear i hit 40, 2nd 80, 3rd 110, 4th 130@5k rpm
Old Oct 23, 2001 | 08:56 AM
SVTTODAMAX's Avatar
I would have to agree with toylet902 because I didn't get near the fuel cutoff so my redline is similar to his + or - 5mph.
Old Oct 23, 2001 | 09:33 AM
maxse01's Avatar
I dunno. I read it in a magazine that was the maximum speed in each gear and i have gone as high as i can and still never get above 38 or 39 in first, close to 70 in second, close to 100 in 3rd and i shifted at 6700 rpms at 130 mph in 4th. When i hit 153 mph i was at 6400 rpms.
Old Oct 23, 2001 | 09:37 AM
ToYLeT902's Avatar
JET Speed Lab
I dunno. I read it in a magazine that was the maximum speed in each gear and i have gone as high as i can and still never get above 38 or 29 in first, close to 70 in second, close to 100 in 3rd and i shifted at 6700 rpms at 130 mph in 4th. When i hit 153 mph i was at 6400 rpms.
maybe jOO speedo is mess up and not ours. but then again, wonder what the rest of the 5spd ownsers have to say...
Old Oct 23, 2001 | 10:24 AM
SVTTODAMAX's Avatar
That would be true if the car was stock but modified you have more horses to push troughout the RPM. I was just wondering if some other people got the same results.
Old Oct 23, 2001 | 11:03 AM
Y2KMaxGXE-R's Avatar
what is the size of your wheel/tire combo? If you used wrong tires on the rim, that could get your odo off. Anyone had installed the same catback and dynoed the car? I'd love to redline 100mph in 3rd..
Old Oct 23, 2001 | 11:05 AM
Dave B's Avatar
Not DAVEB the parts guy
Somehow your speedometer has gotten messed up. It doesn't matter if you add 400hp, you'll still be limited by the gearing and rev limiter set at ~6600rpms. The gearing never changes regardless of power increases. The 4th gen Maxima has a redline of 6550rpms which is exactly like the 5th gens. Maximum mphs in each gear is 38mph 1st, 67mph 2nd, 97mph 3rd, ~130mph 4th, and 5th I don't know.
BTW, the tachometer is off by ~200-400rpms depending on gear according to my shiftlight. The lower the gear, the more the tachometer is off. Why does it do this? Because the tachometer is mechanical and doesn't "rev" up as fast as the motor does. I can do nearly 7000rpms in 1st even though the rev limiter is set at 6550. 4th and 5th are pretty accurate.
Dave
Old Oct 23, 2001 | 11:06 AM
SVTTODAMAX's Avatar
Actually right now im rolling on my stock wheels & tires.
Old Oct 23, 2001 | 11:11 AM
maxse01's Avatar
Re: Re: Re: 5 Speed shift points.
Me too. Stock 225/50 vr 17's I have checked it and it's dead nuts on. I think dave is right
Old Oct 23, 2001 | 12:10 PM
Rob'sAE's Avatar
You're Faster, I'm Better
I love redlining 3rd at 120!!! AUTOMAGIC OWNZ UUUU ALL!!!
Old Oct 23, 2001 | 12:11 PM
ToYLeT902's Avatar
JET Speed Lab
poor mis-guided child.
Old Oct 23, 2001 | 12:27 PM
SVTTODAMAX's Avatar
I remember you stating you could only do around 130-135 in you automagic I can go past that. J/K!!
Old Oct 23, 2001 | 01:25 PM
maxse01's Avatar
Re: Re: Re: Re: 5 Speed shift points.
HAHA, me too. We have plenty of power at 130-135 to accelerate past that. All that power comes from having the right gearing to go that fast.
Old Oct 23, 2001 | 03:09 PM
Rob'sAE's Avatar
yeah yeah yeah.... When I bought the car my wife had to be able to drive it, plus there was not a 5spd AE within 200miles of me... oh well... if I want to drive a 5spd I can always borrow my moms saturn
Old Oct 23, 2001 | 03:13 PM
ToYLeT902's Avatar
JET Speed Lab
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
hayne
Oct 5, 2015 11:53 AM
