redline anyone?
Old Nov 21, 2007 | 07:29 AM
  #41
NmexMAX's Avatar
dot dot dot ...
Originally Posted by MaxBoost925
I knew both of these thangs. Am I OG qualified?
Wow, and you're not even in his engineering program.
I guess I'm always making my point in a way that the person I'm trying to make a point to has to understand it is before they understand me, hence they might try and research a little on the subject.
point is, just because the engine isn't making peak power @ a certain RPM, doesn't mean you shouldn't rev it there. People w/ 4AT's and people who have any 4th gen experience both know that even if power drops off slightly(4-6%), you're still in good shape and setting yourself up for maximum power in your next gear.
The reason I mention 4AT's is because we all know how horrid the gear ratios are, so, in order to take full advantage, we need to make some decent power, AND be able to shift further (extended rev limiter) even though we may not be making max power/torque @ said rev limit. Oh yeah, the reason I mention 4th gens is because they are known to drop ~ 40 - 50 whp from 5200RPM-6500RPM, so any gain over that is looked at as a plus. And I obviously come from both those criteria.
My last 2 dyno sessions were a prime example of how misunderstood peak numbers are and even when they occur.
On my most previous dyno run, the car showed a peak hp @ 5900 RPM. Seems low in comparison to my run before that, where peak was @ 6300 RPM. Ok, cool, what's the assumption we come to? The 6300 RPM run is probably making better power than the 5900 RPM all run anywhere past 5900 RPM, all the way to 7100RPM rev limit, right?
The run that peaked @ 5900 made ~10 whp from 6500-7100RPM vs the run that peaked @ 6300
You see how that happens?
Old Nov 21, 2007 | 08:47 AM
  #42
Bborges's Avatar
Originally Posted by NmexMAX
How 'bout a dyno?
What about a dyno? did I exclude that option? did I say "the only way to measure" or "one way to measure"? are u bored at work?
Depending on RPM, you could still be gaining in horsepower, EVEN if the torque is dropping. But you knew that.
Dude, you are privileged to drive a very well known engine for having a nice torque deliver. You can shift your VQ virtually at any point because it delivers torque. there's no arguing that. The problem is when you get out of the VQ world and start dealing with peaky torque curves.
Get on a zetec engine for instance and try to race shifting at redline and you'll see how well it will perform.
Old Nov 21, 2007 | 09:10 AM
  #43
NmexMAX's Avatar
dot dot dot ...
Ok 'dude' but this isn't a zetec forum, I don't have any interest in a zetec forum/car/engine.
A dyno is more informative/definitive than an accelerometer, also, did I ever say you excluded the option of a dyno? Does it matter what I'm doing at work?
Old Nov 21, 2007 | 09:29 AM
  #44
MaxBoost925's Avatar
Drug Money
I don't have a computer at work.
I serving duh Chop Suey.
Old Nov 21, 2007 | 10:04 AM
  #45
NmexMAX's Avatar
dot dot dot ...
Carne Asada. ....
Old Nov 21, 2007 | 10:07 AM
  #46
Drug Money
Carne Asada. ....
dayum cuz, you don't know how long it's been since i had genuine carne asada fries.
user 11122324
42
Jul 18, 2022 03:35 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
3rdmaxse0
Aug 18, 2015 08:25 AM
1997 Maxima SE
Nov 24, 2000 01:37 AM
