stalling...please help
Old Nov 21, 2007 | 01:11 PM
2003SE
What are some of the symptoms of a bad coolant temperature sensor?
What are some of the symptoms of a bad intake air temp sensor?
Thanks Guys...
Jimmy
Old Nov 21, 2007 | 09:02 PM
jasonmax's Avatar
i think it's the o2 senser, any codes?
Old Nov 21, 2007 | 09:18 PM
2003SE
Jason, SES light was ON (P0138) Oxygen Sensor 2 bank 1.... I replaced that sensor and the SES light went OFF but the stalling issue still exists.
The problem: Car starts fine ONLY when the engine is cold. Once warmed up and I turn the car off, When I turn the key to start it again--- car starts fine then it stalls right away UNLESS you immediately hit the gas gently. Someone suggests it MAY be a bad coolant temperature sensor.
Old Nov 21, 2007 | 09:24 PM
jasonmax's Avatar
try to reset the ECU I would suggest
Old Nov 22, 2007 | 09:21 AM
2003SE
Won't reseting the ECU remove the SES light on the dashboard? NO SES light is ON.
Old Nov 22, 2007 | 06:16 PM
Daredog's Avatar
i have a 2000 and similiar stalling problem, dealer installed new maf, reprogrammed ecu, and new air filter, problem is gone.
Old Nov 22, 2007 | 06:43 PM
2003SE
The maf deals more with air volume, not so much air temp. I'm hoping its not the MAF because that thing is expensive.
Daredog, how much did you spend at the dealership? What were some of the problems you were having with your car?
Thanks,
Jimmy
Old Nov 22, 2007 | 07:17 PM
jasonmax's Avatar
Thanks,
Jimmy
try to dis&reconnect your maf and reset your ECU
I always start trying things that won't cost any money
Old Nov 23, 2007 | 02:45 PM
2003SE
I believe the MAF and the throttle body should be cleaned. Maximas get a build up of black gunk i the body and it prevents the air from flowing smoothly thus causing the car to stall...A local mechanic should be able to fix this & not the dealership.
Thank you for being helpful.
