Tachometer Not Working Fully
Old Nov 22, 2007 | 02:00 PM
Game_Time's Avatar
As I was driving yesterday, I noticed that my tachometer wasn't fully functioning correctly. I have a 5 spd 2000 GXE and I was pushing it yesterday, but I noticed that my tach only goes up 3400 rpm and no higher. The car isn't struggling or anything, it moves as normal, but the tach just won't go above 3400. I was idleing at a light and revved it, but it works fine up 3400 and stops there until i left off the gas and it will drop back down to idle speed. Does anyone know what might be the cause of this? Thanks in advance.
Old Nov 24, 2007 | 04:57 PM
11-YEARS-DEALER-EXP's Avatar
Its probably going to be in your tach guage if the vehicle runs normal.
Old Nov 25, 2007 | 09:26 PM
Game_Time's Avatar
Has anyone had to replace their tach before? I really don't know how a tach works in correspondence to the engine speed, but I would imagine that the tach in the instrument cluster shouldn't be too difficult to replace, but what about the "sensor" or whatever the tach uses to read the engine speed? I would imagine that it would be difficult to fix. Would anyone care to shed some of their knowledge or experience on this matter? Thanks.
Old Nov 26, 2007 | 12:25 PM
NmexMAX's Avatar
dot dot dot ...
My guess is that the tach is physically sticking. If there is/was a sensor problem, the car would not run correctly and you would likely gete an SES light.
In short, a magnet is attached to a sensor and that magnet reports a frequency to the ECU, thus giving RPM feedback. This is a vital function not only for the tach, but for other systems in the car (electronic/driveability. And since you say the car drives fine, my guess is that the you can rule our sensor/electronics.
If I were you, I'd locate a 'How To' for changing gauges and use it as a blueprint for diagnosing your problem (sticking tach needle i.e. take dash aprt and see if the needle is sticking.
Matt93SE
May 24, 2019 02:58 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
max1029
Aug 26, 2015 09:51 AM
ChrisIve
Aug 22, 2015 03:04 PM
kenc15
Aug 5, 2015 08:29 AM
