new coils.....still missing
Old Nov 27, 2007 | 11:27 AM
icewake's Avatar
Alright so my car ('00) was missing every now and then and I got the standard engine miss code, P1420 maybe, dont remember exactly. When I saw that I ordered 6 new coils and put them in on Sunday. Today I noticed a slight miss again while i was backing up. Also, I replaced the spark plugs with NGK platinum (or whatever the expensive ones are) a year and a half ago. Does anyone have any thoughts?
icewake's Avatar
btw.......another code has NOT shown up yet
Old Nov 27, 2007 | 02:55 PM
jasonmax's Avatar
O2 sensor?
Fuel system?
Old Nov 27, 2007 | 03:18 PM
Cli-Max's Avatar
I was thinking bad fuel, but it's missing in reverse. Maybe recheck the gap in the plugs and reset the computer.
Old Nov 27, 2007 | 06:47 PM
Kyle00's Avatar
WSH for teh cup
Have you installed a new MAF at any point? Keep the MAF in mind.
Old Nov 27, 2007 | 08:45 PM
wyche89's Avatar
MAF is the defaut culprit for all performance problems.. lol
Old Nov 27, 2007 | 10:02 PM
icewake's Avatar
ill look into possibly getting a maf in a few months but for now i think i am going to check spark plug gaps. also note that after i installed the new coil packs it was not missing as much or as big of a miss as before. not sure if that might help in any diagnosis but wanted to throw it out there
Old Nov 29, 2007 | 06:39 PM
Matt_01SE_20th's Avatar
A miss is a miss, reverse has ZERO impact.
As mentioned, MAF could be culprit, but typically doesnt cause misfire. I would check injectors as well. You may also want to elaborate on "miss" because often times people say its a miss when there is just stuttering or chatter.
EDIT/ADD: Dont delay on this, if you are truly missing due to spark you are POURING raw fuel over the catalyst, if you have a cali-spec this is especially bad. when i had misfires i waited because it was so intermitent, bad idea, front pre-cat went out.
Old Dec 2, 2007 | 02:38 PM
ShiftVQ35
replace the maf sensor next......
jmlee44
Oct 2, 2022 02:13 PM
conansriver
Nov 18, 2015 02:46 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
conansriver
Sep 16, 2015 12:17 PM
