P0301 code...possible cause of SSIM?
I just put the SSIM on my car a few weeks ago and it runs fine...well a few days afterward it threw the P0301 code (misfire in cylinder 1), everyone I've talked to just says get new plugs but my dad thinks that maybe the manifold is making the car do this...I reset the ECU and the code stayed off for about 1 1/2 weeks and then I started the car to warm up and then when I got in I noticed the SES light was on again...so it's something with the idle...do you think the code is just a quisedence and I need new plugs or do you think that maybe my intake manifold is doing this.
I was thinking about that...I was gonna switch the coil from 1 and 2 and then see if it throws a P0302 (misfire in cylinder 2) then I will know for sure...thanks for the help. But one more question, ever since the SSIM the car idles sort of different, do you think the Idle Air Volume Re-Learning Procedure would help this?
So if your coils are just starting to fail, you too may be unsuccessful. In theory it's a good idea and is worth a try
I tried this same procedure before I got updated coils but was unsuccessful. My coils were misfiring, but inconsistantly it seems. The coils misfired for sure, but it was random I think because they were just starting to go bad.
That could be the case but the code just keeps popping up as misfire in cylinder 1 though...is it possible to only be just the #1 coil? Also how much am I looking at for coils?
Now that I think about it.... I first got the cylinder #1 misfire code and then later got the "random cylinder misfire" code which is when I replaced them all
Alright I did the idle/air relearning procedure cause I figured it couldn't hurt and I started the car and then the light came on again but the weird thing was that whenever I would rev-up the motor the SES light would go away and then with no throttle it would light back up?
Well I replaced the coil and it still did it so I took the manifold off and then put my old one back on and guess what...no more problems...so the SSIM was the cause of the bad idle/ P0301 code...
A quisedence??? LOL, man I took off that manifold and put the stock one back on and it fixed the problem...I obviosly didn't do the gutting good enough and that resulted in the problem.
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
Help P0301
Hi Guy,
Thank you everyone for your contribution, I have 02, maxima with a P0301 Code.
now after reading this thread,I decided to change the Coils and spark plugs for all 6 cylinders. However after changing them, I still getting the error code.
I cleared out the code but still the same code comes back
Any suggestion or helps will be kindly appreciated
P0301
Hi Guy,
You need to use OEM Genuine Nissan Ignition coil to solve this problem. I recommend to replace the ignition coil 1,3,5 with OEM Genuine Nissan Coil.
2,4, 6 (accessible) you can use the OEM Nissan Aftermarket parts (rockauto.com) Hitachi brand.
Avoid ebay , online or auto store Aftermarket parts, because this parts sometimes remove the error code but the problem persist.
Good Luck
@colt149 - the OEM stuff are sh*t too...
I bought brand new ones for the rear (3 in total) due to the advice on this forum and they were $$$ but I got a faulty batch. Had to open the car up again, return the coils, wait for the replacement etc but the second ones have been fine so far.
Point being, it might be worth it to risk going aftermarket
Help P0301
Colt
I think my issue is genuine and not just a false error code. , since the tell tell signs were clear
1. The engine vibrates a lot on idle.
2. White smoke from exhaust
Do you really think that an OEM coils will solve the problem along with changing the gasket like this kid did on his altima
G10
G10
VQ35DE engine is picky when it comes to sensor. OEM Genuine Nissan parts is the way to go . Aftermarket sensor will last for a short time. Your problem here is the aftermarket ignition coil.
OEM ignition
Do you think I depend on it , I use my common sense. I tested the new OEM ignition coils by placing it on the front bank 2,4,6 (accessible) and run the car with it for two days. I have my own OBD II scanner with live feed check for error code and pending error code. Without any code or SES light I am sure that those coil are not defective. I replaced the rear bank with those brand new tested OEM Genuine Coil
pimpin02max
12-27-2007 02:54 PM
