P0303 Code? Yes, I searched first
Old Nov 28, 2007 | 07:50 PM
cabernet's Avatar
2 weeks ago I pulled a P1320 code and knew it was a coil but haven't got around to replacing it. It wasn't a problem since it's an intermittent thing. Now I get a P0303 code. I'm hoping it refers to cylinder 3 ignition is bad and not some oxygen sensor. If it's cylinder 3 is that the middle rear?
I tried the sticky about CEL codes but the links are all bad. I tried the Yahoo search and came up with mostly threads about people with 303 posts.
Thanks in advance.
Old Nov 28, 2007 | 08:06 PM
SoonerFan's Avatar
Cletus
get new coils
/thread
Old Nov 28, 2007 | 08:12 PM
cabernet's Avatar
Originally Posted by soonerfan
get new coils
/thread
Yes, I already have them and just haven't had a chance to install them. I wanted to make sure that P0303 wasn't related to something else.
I think I've found that P0303 is a bad ignition in the rear middle cylinder so it must be the same problem. I have new plugs to put in too since the current one have more than 100K on them.
Old Nov 28, 2007 | 08:23 PM
SoonerFan's Avatar
Cletus
so if you know its the coils...and you have the coils...what is your question?
Old Nov 28, 2007 | 08:28 PM
cabernet's Avatar
The search on this site turned up "front oxygen sensor" for 0303. After I posted I searched other Nissan sites which indicated it's not a sensor problem. I wanted to make sure it's just one problem and not two.
Old Nov 28, 2007 | 08:40 PM
MacGarnicle's Avatar
I suppose you'd find out after you installed them wouldn't you
I hope you didn't buy 6 new ones?
Old Nov 28, 2007 | 08:43 PM
SoonerFan's Avatar
Cletus
if one goes bad, its best to replace them all since they will all go out soon after the first. they should be like plugs...change all 6
Old Nov 28, 2007 | 08:49 PM
cabernet's Avatar
I bought 6 new ones but so far only installed the front 3. I was glad to see that one of the rears failed instead of one of those that I had replaced. I've had the P1320 code many times but this is the first time I pulled a different code.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
