Spark Plug change?
Old Dec 4, 2007 | 01:42 PM
hotstartup's Avatar
Spark Plug change?
my car is presently at 80k miles on the original plugs. I have noticed a little play on the rpm gauge at idle. Just got done with the oil and tranny fluid change, will look to change the spark plugs and drop in a k&n air filter. What do you guys normally recommend for plugs? also how hard is it to do this on the 3.5? thanks!
Old Dec 4, 2007 | 02:25 PM
maximadave's Avatar
detailerdaveb@gmail.com
http://forums.maxima.org/showthread....ht=SPARK+PLUGS
Old Dec 4, 2007 | 02:26 PM
NmexMAX's Avatar
dot dot dot ...
There is a sticky on top of the page labeled, "How To's".
And another sticky labeled "WHAT TO DO WHEN A LINK TO A THREAD IS BROKEN (STICKIES, SEARCH RESULTS, ETC)"
Between the 2, you will find your answers.
Old Dec 4, 2007 | 02:36 PM
hotstartup's Avatar
thanks guys
Old Dec 4, 2007 | 02:55 PM
2002 Maxima SE's Avatar
Follow these instructions and you'll be done in a few hours.
http://www.greghome.com/Greg's%20Gar...eplacement.htm
Old Dec 4, 2007 | 03:01 PM
hotstartup's Avatar
could the tiny bounce in idle be because of the spark plugs? Ive noticed it after getting my tranny fluid changed, but that could simply be because i was trying to notice for it afterwards.
Old Dec 4, 2007 | 04:46 PM
Scottwax's Avatar
That's Mr. Detail to you
Since you have to pull the intake on the 3.5, you ought to look into adding a phenolic spacer while you are at it.
http://forums.maxima.org/showthread.php?t=384774
Old Dec 4, 2007 | 05:35 PM
'02_EMILBUS's Avatar
those phenolic spacers are expensive though ScottyW... the main purpose for them is just to cool the intake air, correct??
Old Dec 4, 2007 | 06:00 PM
hotstartup's Avatar
sounds like a PITA, should be fun though as long as everything goes back smoothly.
wonder why they made it so complicated to get the rear ones done.
Old Dec 4, 2007 | 07:45 PM
Scottwax's Avatar
$225 for a claimed 10 hp and 12 lb-ft is a bargain. A cat-back, for example, would be twice that and maybe-if you are lucky, half the gains.
If you are going to go to all the trouble to remove the intake to install new plugs, if the cost of the spacers is in the budget, it seems to be a good idea to get them.
Old Dec 4, 2007 | 07:47 PM
SoonerFan's Avatar
Cletus
if only we had stickies, FAQs, and a newbie thread. that would be great
Old Dec 4, 2007 | 08:24 PM
Scottwax's Avatar
If only.
Old Dec 4, 2007 | 08:27 PM
well i don't know who has an extra $225 in their budget while changing spark plugs??
But definitely a good idea to do since its all apart!
And if only we had some normal people in here.... we all have our wishes Sooner
Old Dec 4, 2007 | 08:35 PM
Scottwax's Avatar
It isn't like we have cheap cars....
Remember, this is the internet. We are all filthy rich, date supermodels and our other car is a Ferrari, Porsche or Lamborghini.
Old Dec 4, 2007 | 08:36 PM
SoonerFan's Avatar
Cletus
if only we had people that respected and followed the rules and guidelines.
Old Dec 4, 2007 | 08:46 PM
ROCKART's Avatar
wants an I35
ive heard bad things about the K&N dropin filter. a number of org members told me not to use it. read this = says the OEM is the best filter (or one of the best)
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Old Dec 4, 2007 | 08:50 PM
s2kver02's Avatar
do you have to take off the intake manifold on an 2k maxima to replace spark plugs?
Old Dec 4, 2007 | 09:04 PM
Scottwax's Avatar
5th gen, no, 5.5 gen yes. At least from what I've read on the board.
Old Dec 4, 2007 | 09:05 PM
SoonerFan's Avatar
Cletus
no
Old Dec 5, 2007 | 06:28 AM
NmexMAX's Avatar
dot dot dot ...
mvm062
Nov 30, 2020 09:00 AM
knight_yyz
Nov 6, 2015 02:34 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
