Can someone help me out and photochop the "slotted" section at the bottom of the Stillen lip to be black. I've done the crappy MSPaint version, but that does not give a good enough idea of how it would look.
Hopefully sickmax doesn't mind me using his pic as the test mule.
TIA.
TIA.
TIA.
i'm sure he won't only because he is no longer a SICKMAX. Originally Posted by MixSER6
Can someone help me out and photochop the "slotted" section at the bottom of the Stillen lip to be black. I've done the crappy MSPaint version, but that does not give a good enough idea of how it would look.Hopefully sickmax doesn't mind me using his pic as the test mule.
TIA.
i would photoshop it for you, but i don't have photoshop installed. reformat FTL.Quote:
Not quite what I had in mind....it needs to have the visible parts painted black as well. To make it look like that area is "empty".Originally Posted by Professor`
Hows this for 5 mins in adobe?
So it would end up looking similar to this:
Thanks for the help!
AWESOME! Thanks soonerfan! That's exactly what I was looking for, man you're my savior!
im really liking the pic is post #5 with the dual exhaust. That is a really cool rear lip. To bad its not in production.
^ YES! Thank you very much Tondeuse!
Hmmmm.....not bad looking. Might have to do this come next spring-time.
is this your car The Law?Originally Posted by MixSER6
Not quite what I had in mind....it needs to have the visible parts painted black as well. To make it look like that area is "empty".So it would end up looking similar to this:
Quote:
I thought about that, but I am not sure how sturdy these pieces are? I am also not sure if they can fill in the holes? What is the Stillen piece made out of, polyurethane?Originally Posted by SEmy2K2go
What about just cutting that section out?
I'm a fan of the dual exhaust tips as well. Does any company make them, cause I've been searching and this is the closest thing I've seen so far:
http://custommaxima.com/product_info...ducts_id=45684
i was lookin into the rear diffuser look also, but there no way you can use any other cars because they either have dual, dont fit, or the exhaust cut is on the left side. would be nice if stillen designed a rear diffuser version of the rear lip. shoots i even looked up an actual rear diffuser itself as an add on and they cost from like $800-4000!
TIA.
did you photoshop the drop or do you ride like that, cause i tried riding like that and my axle blew out on me on the highway almost sending me out of control lol...Originally Posted by MixSER6
TIA.
Quote:
It's not my car, it's sickmax's. I do not believe his drop is chopped, I think he actually rode around like that.Originally Posted by Grand_hustle17
