Dangerous splash guards in snow
Old Dec 19, 2007 | 09:25 PM
jasonmax's Avatar
I have snow on the road for almost a month.
Everytime I drive my lovely Max home or to school, I notice there are a lot of snow collected in the wheel wells. Once they get frozen, they can be very dangerous b/c when I go through bumps, wheels go up and hit the snow/ice. b/c the snow/ice are so hard, you actually hit your wheel wells.
Why it is very dangerous? When I look into the rear driver side wheel well, there is a gas tank filling hose which you will hit if you have snow/ice in the wheel well.
How does this happen? The splash guards which won't allow snow and ice getting out. And I looked at other cars, they didn't have snow/ice in the wheel wells b/c they didn't have splash guards.
btw. getting ice and snow out of wheel well is such a pain. I ended up pouring warm water on them..
Old Dec 19, 2007 | 10:43 PM
SoonerFan's Avatar
Cletus
was never a problem for me during 4 DC winters.
never heard anyone else have a problem
Old Dec 19, 2007 | 10:55 PM
spdfreak's Avatar
Hasn't happened to me and it's been snowing on and off for three weeks now.
Old Dec 20, 2007 | 12:27 AM
Eastern's Avatar
Im having the same problem...
Old Dec 20, 2007 | 04:45 AM
MichMaxFan's Avatar
It may just be the angle of the pic or just me, but it looks as if your tires are extremely close to the wheel well and splash guard trim??? If so, that could be your problem.
Old Dec 20, 2007 | 05:29 AM
Prophecy99's Avatar
....after a drive through the snow and that collects, once I park...I tend to just bang it out with my ice scraper before it can become solid and a problem....
Old Dec 20, 2007 | 06:43 AM
Maxgig's Avatar
I had a similar issue last winter, but I do what Prophecy99 does and luckily here in KS we have hot water car washes. So I wash my cars no less than 2 times a week to keep them grit and grime free.
Old Dec 20, 2007 | 06:49 AM
jasonmax's Avatar
en...these are stock, so it can be everyone's problem..
Old Dec 20, 2007 | 06:54 AM
bjr's Avatar
bjr
Its happening to me, doesnt really seem to be all that big of a problem though. I used a broken hockey stick shaft to get that snow/ice out..
merlin2375's Avatar
Seems like a strange problem, I haven't had this problem. What kind of tires are you running? Are they snows? Maybe it's the tread pattern that's throwing all the snow up that way instead of channeling it out to the sides?
Old Dec 20, 2007 | 06:57 AM
MintVQ35's Avatar
That's not a real problem, if you clean your car off properly when it snows you'd be kicking as much of that stuff out of the wheel wells as possible like I do...haven't had any problems yet and have never had a problem with any other vehicle with splash guards.
Old Dec 20, 2007 | 07:07 AM
jkayca's Avatar
I have snow build up just as jasonmax describes. I agree it's hard to get out due to the splash guards. Like others have said, you need something to dig it out. Simply kicking the splash guard/fender area doesn't do it. Well unless you give it a really good whack but then you risk damaging the car .
However, I've never had an issue with "bumping" and the build up causing any real problems. Eventually the snow/ice gets so heavy it falls out on its own.
Old Dec 20, 2007 | 07:34 AM
Iceman420's Avatar
(insert witty one liner)
That's what I do and have never had a problem.
Old Dec 20, 2007 | 07:40 AM
jasonmax's Avatar
I'm running on Mud+Snow tires.
Old Dec 20, 2007 | 07:41 AM
jasonmax's Avatar
I don't have patient to knock them out, I just pour warm water on it..
Old Dec 20, 2007 | 11:03 AM
Teufelhunden's Avatar
i never really had a problem with it. just scrape it off with the snow scraper whenever you can.
Old Dec 20, 2007 | 11:12 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Happens with my car as well, but I don't worry about it.
You don't have patience to knock ice out of the wheel wells, but you have patience to go inside, wait for hot water, go back out and pour it over the ice?
Old Dec 20, 2007 | 12:00 PM
2002 Maxima SE's Avatar
There is a fuel filler shield that was omitted from the 2002/2003 Maxima that you can buy that will fill that area. I can't recall the part number but just ask your nissan parts store rep. The shield attaches with a few clips.
Old Dec 20, 2007 | 12:31 PM
Iceman420's Avatar
I was thinking the exact same thing.
Old Dec 20, 2007 | 12:42 PM
jasonmax's Avatar
That's when water heater does the best job..
Old Dec 20, 2007 | 12:43 PM
jasonmax's Avatar
thanks a lot
Old Dec 20, 2007 | 01:37 PM
jeff5347's Avatar
same for me. i am **** about keeping the slush and ice off my car. A little preventive medicine goes a long way
Old Dec 20, 2007 | 03:02 PM
thanks a lot
You're in luck! I found the receipt with part numbers:
Protector-Filler 17290-2Y000
Clip (you need4) 01553-09321
Old Dec 20, 2007 | 04:30 PM
PeteCool's Avatar
Same thing happened to me a few weeks ago, with your first snowfall (10-12 inches). It was bumping hard even over very small bumps.
Took me a few minutes to figure it out. I went through worse snowfalls before with my other cars, and this never happened.
Old Dec 20, 2007 | 06:18 PM
nismowolfe's Avatar
This happened to me this year already but melted quickly because it warmed up. I would just do any ot the above suggestions and you should be ok.
Old Dec 20, 2007 | 08:28 PM
irish44j's Avatar
retired moderator
I just kick the mudflaps when I get out of the car when theroads are snowy.
Old Dec 20, 2007 | 08:29 PM
irish44j's Avatar
retired moderator
btw, I can't believe you run those garbage Eagle RS-A's in the snow/ice.....I can't think of a worse tire to be using.....Just because they call them "all season" doesn't make it true.
Old Dec 20, 2007 | 08:59 PM
DrunkieTheBear's Avatar
Turbo'd Saab
never seems to be a problem with me, oh wait...florida, I have the A/C on right now
Old Dec 21, 2007 | 04:28 AM
nsnrider's Avatar
if it bothers you so much, take off your mudflaps for the winter.
Old Dec 22, 2007 | 07:38 AM
MintVQ35's Avatar
Just kicked my mudflaps out yesterday, worked great.
Old Dec 22, 2007 | 08:27 PM
Tondeuse's Avatar
Well, This happened to me everyday since 3 weeks, because the huge amount of snow that fell these days, and I'm on 16" winter tires. So the tires aren't the only issue.
Just like Prophecy, used the scrapped to remove the snow but took a lot of time to remove it. A simple kicking-on-th-mudflaps-technique isn't enough to remove the huge amount of snow stuck after a 10 min run in these conditions.
Old Dec 24, 2007 | 10:49 AM
01ToTheMax's Avatar
I experienced the same issue with the snow/ice buildup when running the stock potenzas. I now have a set of 17" toyo observe snows on it, and although the snow still tends to build up, I find that when I hit a bump the tread from the tires seems to just break the snow up and pull it out.
I still try to knock out whats in the wells at night just to keep the snow from turning to ice.
Old Dec 24, 2007 | 02:50 PM
phatmax95's Avatar
Old Dec 24, 2007 | 02:58 PM
spdfreak's Avatar
Originally Posted by phatmax95
I would assume that happened because you let your wheels spin. I have never seen that though.
Old Dec 24, 2007 | 03:32 PM
phatmax95's Avatar
Probably the melting and re-freezing of the ice. It was probably above freezing that day.
Old Dec 24, 2007 | 04:06 PM
mist max2000's Avatar
yeah man.. same thing happened to me.. i was driving.. and im like wtf is that noise.. yeah ice in there... are u lowered? because i think that has potential to have something to do w it.. cuz i just noticed it this winter for the 1st time after lowering.. not the same clearence for snow to pass through
Old Dec 24, 2007 | 04:52 PM
jasonmax's Avatar
my car is full stock.
DJLAX152
May 4, 2021 11:46 AM
knight_yyz
Nov 1, 2015 01:34 PM
jc53
Oct 12, 2015 05:12 AM
mclasser
Sep 6, 2015 09:05 AM
