Courtesy FTSB hitting underside of hood.
Old Oct 25, 2001 | 02:11 PM
2maxguy's Avatar
Anyone have trouble with the Courtesy FTSB not fitting correctly and hitting underside of hood? Even closing hood takes more pressure and upon pulling the release, the hood pops up much harder than before. Any thoughts or fixes.
Old Oct 25, 2001 | 03:05 PM
BigDogJonx's Avatar
Good thing I ghetto-rigged a 4thgen FSTB in my joint.
Old Oct 25, 2001 | 04:01 PM
WILLSE's Avatar
the stillen one hits too! i have noticed nothin big just the black undercoating of the engine! oh well
Old Oct 25, 2001 | 04:07 PM
EdV2K's Avatar
my Stillen hits too, nothing major though
Old Oct 25, 2001 | 04:45 PM
UMD_MaxSE's Avatar
Got Bent?
never really noticed
Old Oct 25, 2001 | 04:48 PM
psing23's Avatar
mine doesnt...
Old Oct 25, 2001 | 05:01 PM
Tanman's Avatar
Maybe you got it installed incorrectly?
Old Oct 25, 2001 | 05:25 PM
woosh's Avatar
My coutesy fSTB touches a bit and yes it takes a bit more pressure to close the hood but no other probs so far. I notice it made an imprint in the foam underside of the hood. Other than that works fine.
I just need more MODSSSS = money!
Old Oct 25, 2001 | 07:45 PM
WILLSE's Avatar
ok how can u install the fstb incorrectly it only goes on one way not that hard!
Old Oct 25, 2001 | 08:56 PM
Tanman's Avatar
Some guys have had problems with their windshield washer nozzles not working because the pressure from the bar is clamping off the flow of washer fluid. You should check yours.
Old Oct 25, 2001 | 10:31 PM
umpopa's Avatar
My Stillen FSTB hits the hood liner a little, enough that some of the red paint from the end of the word Stillen has been transferred to the liner...I really don't see a problem, though.
Old Oct 25, 2001 | 10:40 PM
Sly's Avatar
Sly
Loosen up the lock nuts on and rotate the bar forward and backward a little bit to see if that makes a difference. The courtesy FSTB allows for some adjustability and doesn't have to be perfectly up/down to do its job. BTW, mine is rubbing on the hood liner a little in one spot, and the wiring harness in another, but no real issues so far.
Old Oct 25, 2001 | 11:51 PM
Menasor's Avatar
I used to have that problem but not anymore since I moved it. Other than that i have no problems with it.
Old Oct 26, 2001 | 12:00 AM
yongjun's Avatar
NO
Old Oct 26, 2001 | 06:54 AM
bcannon's Avatar
no problems here...
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Dec 12, 2015 09:39 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Domf3
Sep 22, 2015 03:05 PM
