Weird idle and 1126 code
Old Dec 26, 2007 | 09:10 PM
Maxim24's Avatar
My '00 AT has developed a weird idle on cold startups. It sounds like it's gonna stall for a few seconds, then idles good for a few, then sounds like it's gonna stall again for a few seconds, then recovers...and it repeats until the car is warmed up. When at "warmed" temp, it idles fine and runs perfect. No SES lights had come on until yesterday. I pulled the code and it was an 1126 "Thermostat" malfunction. Cleared it and it has not reappeared after driving it today. When I pulled the code yesterday while the car warming up and doing the weird idle, I observed the one of the o2 sensors not reading properly on the live data.
If it was a bad o2 sensor, would it matter if the car was cold or warm? Anybody have any similar symptoms or tech support. Appreciate the help.
Old Dec 29, 2007 | 04:27 PM
dazalfolks's Avatar
You may very well have a bad o2 sensor. During cold starts, your Max will run rich as a safety precaution, till it warms up to normal operating temperature. This is normal on almost every car for a warm up procedure. I would suggest you have your o2 sensor checked/replaced.
Old Dec 29, 2007 | 04:43 PM
NmexMAX's Avatar
dot dot dot ...
It’s not a safety precaution. 1126 is your thermostat function.
On Board Diagnosis Logic
Engine coolant temperature has not risen enough to open the thermostat
even though the engine has run long enough.
This is due to a leak in the seal or the thermostat open stuck.
Malfunction is detected when the engine coolant temperature does
not reach to specified temperature even though the engine has run
long enough.
Possible Cause
I Thermostat function
I Leakage from sealing portion of thermostat
I Engine coolant temperature sensor
Old Jan 11, 2008 | 09:49 AM
correa85040's Avatar
2001 Maxima
The new cars depend on the thermostat to operate. Some of the thermostats stay open to prevent it from overheating. Maybe it is open and it is taking longer to get to opertaing temp.
Old Jan 11, 2008 | 05:40 PM
NmexMAX's Avatar
dot dot dot ...
That's exactly what's happening here.
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
