How to pull TCM codes?
Old Dec 28, 2007 | 12:09 AM
made in china's Avatar
Ok, yes I know the answer to this...use a scan tool and get the codes, OR use the key/gas pedal/brake pedal trick. Heres my prob:
I have the 2004 I35 drivetrain, ECU, AT and TCM. My "AT CHECK" light flashes when I first start the car. So, I did try to pull TCM codes using the key/gas/brake pedal procedure to no avail.
Today, I had the codes pulled using a very nice OBD-II scanner a mechanic friend has. He was able to pull the codes for the ECU, but the TCM did not show up in the list. I have pins 12 and 13 connected in my data link connector, but they are noted as being "consult data out" and "consult data in". So, I am wondering if this is data that can only be read by the Consult II that only Nissan techs have?
Anyone successfully pulled codes from their 5.5gen TCM without the Consult II? Or, anyone have the experience that only the Consult can get this data?
My car drives fine. I just get the flashing "AT CHECK" light that goes away after 12 flashes (i think 12) I am pretty sure everything is wired up OK, according to his Scanner, we were able to access all ECU real time data values and everything looks great. I doubt I messed up my TCM connections.
Any ideas?
Old Dec 28, 2007 | 01:45 AM
SoonerFan's Avatar
Cletus
im pretty sure the dealership has to do it and enter the TCM diagnosis mode
Old Dec 28, 2007 | 03:34 PM
NmexMAX's Avatar
dot dot dot ...
I can pull mine via UpRev/Cipher.
Old Dec 28, 2007 | 04:07 PM
cefiro80's Avatar
It you do a search on here I remember an old post that had a guide what the number of flashes diagnoises.
Old Dec 28, 2007 | 04:18 PM
NmexMAX's Avatar
dot dot dot ...
He knows that, he tried it to no avail. I too was not able to get them to flash or anything like that.
Old Dec 28, 2007 | 04:53 PM
SoonerFan's Avatar
Cletus
well i know that show off
i want need it to do that...i dont have a TCM
Old Dec 28, 2007 | 04:55 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by soonerfan
i dont have a TCM
Old Dec 28, 2007 | 11:07 PM
Yeah, I tried that. Could not get it to work.
I was able to get the ECU to flash ECU codes at me using a similar method.
Sounds like I'll need the dealer to look at it.
Mar 12, 2020 12:06 AM
hayne
Oct 5, 2015 11:53 AM
