High beam malfunction
Old Jan 1, 2008 | 12:09 PM
twiggy144's Avatar
Canadian car with stock DRL. The high beam passenger side is lighted with the low voltage DRL as it is supposed to, but when turning on headlamps and hi beams on, it does not lit. Is this a DRL module malfunction? What part do I need to fix or replace ?
Old Jan 1, 2008 | 12:12 PM
n3985's Avatar
大陆弟弟
Fuse?
Old Jan 1, 2008 | 12:15 PM
joshz's Avatar
Hova
Originally Posted by n3985
Fuse?
x2
Old Jan 1, 2008 | 12:20 PM
twiggy144's Avatar
Already checked the fuses, all good. I suspect a bad relay built in the DRL module.
Old Jan 1, 2008 | 01:07 PM
NisTech's Avatar
Very common issue on 00-03 Max. Same with pathfinders too.
Ususally only one side high beam goes.
You need a new Daytime Running Light Module. It's a white box behind pass headlight by washer fluid bottle. 2 10 mil bolts. If i am not mistaken unit is $136. I have a spare one in my toolbox haha
Old Jan 1, 2008 | 03:30 PM
twiggy144's Avatar
Thanks Nistech.
Old Jan 1, 2008 | 05:13 PM
lowincash's Avatar
No More Maxipad
do you think i can add that module into the US maximas? i want DRL for some reason.
Old Jan 2, 2008 | 09:03 PM
NisTech's Avatar
I am not familiar with US vehicles but 99% i am sure you will not have the harnesses where to plug the module in. WE actually install DRL modules on vehicles registered from states and we always run new wires so it's not just a plug and play.
Old Jan 3, 2008 | 01:31 PM
MerlotMax's Avatar
There is a company called Trucklite that sells add on DRL's.-
http://www.truck-lite.com/webapp/wcs...0343&langId=-1
With the way Nissan wires their lamps you would have to use one on each lamp or use one in the fog lamp system.
Old Jan 3, 2008 | 01:40 PM
MerlotMax's Avatar
What will happen to the DRL module is that a solder connection on the circuit board will burn through/break the connection. You can open the module, look for the burned spot and resolder. It will be good for a few more years, or untill another spot goes. Cheap fix.
Old Jan 4, 2008 | 06:25 AM
twiggy144's Avatar
Thanks for the good idea Merlotmax. I will try this when the cold weather eases off.
Old Feb 17, 2008 | 06:20 PM
mbonar's Avatar
Same problem on my 2003 GLE. Guess I'll rip it out when it warms up a bit. Good to know it's a common problem, and not my precious Max starting to get old.
Cheers.
Old Feb 19, 2008 | 05:54 AM
takkar's Avatar
DRL module in Ottawa is roughly CDN$230... NisTech : where did you see for 136?
Anyone know if DaveB sells it
Old Feb 19, 2008 | 11:37 AM
MerlotMax's Avatar
Dave B. won't be selling them as they were not used in the states.
Old Feb 21, 2008 | 12:59 PM
pladwa's Avatar
Yup, had the exact problem on my Maxima... resoldered the unit and all is working fine!
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
