speaker install
Old Jan 5, 2008 | 12:12 PM
papo99's Avatar
speaker install
has anyone ever installed a component set on the front of a 2002 maxima i am trying to install the tweeter in the factory spot and the speaker on the door but i need to find out how did you get the wires from interior to door clean not **** job
Old Jan 5, 2008 | 01:01 PM
redls1's Avatar
MAXIN' ON
Run through the existing place the wires go through. Cant the black boot be pulled out and wires run.
Old Jan 5, 2008 | 01:07 PM
papo99's Avatar
its not a boot its a plug
Old Jan 5, 2008 | 01:13 PM
redls1's Avatar
MAXIN' ON
What I did I think when I had my 350z was there was room to drill holes in the plug and run them through. It was a pain in the butt and took forever to get back in. I re wired the whole car.
Old Jan 5, 2008 | 01:19 PM
papo99's Avatar
i am thinking of pulling the doors off tomorrow
Old Jan 11, 2008 | 11:29 AM
aphiguy's Avatar
Good idea...
Old Jan 11, 2008 | 11:31 AM
hybridioN's Avatar
all teh single ladiez
just cut the plug off, splice the factory wires with the new ones?
if i get what you're saying, that's what i did..at least for the door speakers.
Old Jan 11, 2008 | 11:43 AM
jasonmax's Avatar
I think the aftermarket tweeter is a little difficult because you have to connect it to the crossover.
Old Jan 11, 2008 | 03:06 PM
SoonerFan's Avatar
Cletus
if only there was a subforum for this type of question....i bet the answer might already be there
Old Jan 11, 2008 | 03:33 PM
papo99's Avatar
i checked everywhere and no one had a answer but i figured a way to do it i drilled a hole under the rubber boot connection in the body and the door and added a seperate rubber connection for the speaker wires and it looks like factory
Old Jan 11, 2008 | 09:58 PM
ICEMAN76's Avatar
Get em!! I was about to say something, then, Sooner saves the day!!
Old Jan 12, 2008 | 04:40 AM
papo99's Avatar
f**k sooner
Old Jan 12, 2008 | 06:58 AM
ICEMAN76's Avatar
f**k sooner
Getting a little tense in here..
Old Jan 12, 2008 | 08:10 AM
nismowolfe's Avatar
f**k sooner
I guess according to sooner you should be able to find every answer buy searching, so no one should need to ask a question because all the answers are out there.
Old Jan 12, 2008 | 12:03 PM
SoonerFan's Avatar
Cletus
you people need to man up and stop crying about everything
Old Jan 12, 2008 | 12:36 PM
PrinzII's Avatar
OG and counting...
papo: Consider this your first and only warning on your language. Next time, you are
Old Jan 12, 2008 | 09:30 PM
Edward Lee's Avatar
you don't need to drill anything or take off your door. If you can wait till tomorrow, I willtke a look at my door and tell you how it's done. I fed wires to the door and just recently took them out to relocate the speakers to the kick panels. I can't really remember where the wires were run but think that there is a place right in front of the buckle which is really hard to see but is easily doable. It's a little round rubber grommet that you can go through.
using a hangar type wire and some lube, it's pretty easy. don't drill and don't remove the buckle. it's not needed. I'll take a pic tomorrow and post.
Old Jan 12, 2008 | 09:41 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Drill holes
Old Jan 13, 2008 | 01:25 AM
papo99's Avatar
Originally Posted by SEmy2K2go
Drill holes
i did very similar to that but i put rubber hoses like on top
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
videomano
Sep 8, 2015 03:28 PM
